Old 04-09-2018, 04:48 PM   #1
pcguru2000
pcguru2000's Avatar
Drives: toyota 86 2017
New to this car-have several question
At certain speeds, there's panels or something behind the dash of my 2017 86 that start to oscillate/buzz. All I have to do is change my speed a little and it stops. Is this something the dealership can fix, or is this something that is normal for this car. I've only got about 500 miles on it so far. Certain frequencies from the stereo will also start to make the same thing start buzzing.
2nd question. My torque coolant temp at idle in a parking lot is 200F/93C. Is this normal or should it be running cooler?
3rd question. My wife also owns a Subaru forester xt with cvt tranny. She has Hill assist. I have an auto tranny on my 2017 86. I did the procedure for turning on hill assist but it doesn't come on. According to my dealer sticker, and the toyota website, Hill assist is also available on an automatic transmission. It would be nice not to chirp the tires when switching from the brakes to gas on a 30 degree incline. Supposedly the brakes are automatically activated for 3 seconds, making it convenient.
pcguru2000 is offline   Reply With Quote
Old 04-09-2018, 04:50 PM   #2
DrButtDrugs
yerp
Drives: 2015 WRX
Don't have an AT so I can't speak to 2 or 3, but it's an inexpensive sports car so get used to popping, ticking, buzzing, and otherwise unrefined noises in the car. Just crank up the music and/or install more loud in your exhaust.
DrButtDrugs is offline   Reply With Quote
Old 04-09-2018, 04:54 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Because budget racecar.
200*F is normal for idle, I think are t-stats open up around 203.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
pcguru2000 (04-13-2018)
Old 04-09-2018, 05:25 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
A. Welcome to Subaru ownership
B. That's normal, radiator in this thing is well sized, rock solid coolant temps even when flogging hard, nothing to worry about until you start hitting the track.
C. No idea if you followed the users manual, aside from re-reading that there's always the handbrake or your left foot.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
pcguru2000 (04-13-2018), Spuds (04-09-2018)
Old 04-09-2018, 06:45 PM   #5
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
This car will make all sorts of sounds that take a while to get used to but 90% of the time it is completely normal. As for cabin rattle for me those will eventually just go away and a new rattle in a different place will start. After a few years it won't rattle as much, at least in my experience with this car.
DandoX is offline   Reply With Quote
The Following User Says Thank You to DandoX For This Useful Post:
Old 04-09-2018, 08:30 PM   #6
pcguru2000
pcguru2000's Avatar
Smile
Thanks everyone for a quick response.
Old 04-09-2018, 08:31 PM   #7
pcguru2000
pcguru2000's Avatar
This is the exact info I was looking for!
Old 04-09-2018, 09:22 PM   #8
Welcome to the gang, there, pcguru2000 ..........
As far as the noise behind the dash, I suggest you have your wife drive and you be the gunner, armed with a spray can of silicone with a long barrel, a microfiber rag and a small plastic probe ........ and go squeak hunting.
Back-in-the-day, I used to squeak hunt with several narrow shingle wedges. I would isolate the squeak and shove a wedge in its mouth to shut it up, then simply snap or twist off the unused part of the shingle wedge.
Old 04-09-2018, 11:36 PM   #9
Ghost of Akina
Ghost of Akina's Avatar
Drives: DE5 Integra Type S
mostly this
"Precision without speed is empty, speed without precision, chaos."
Ghost of Akina is offline   Reply With Quote
hill assist
Turn Signal Relay Question (Dumb Question) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 3 06-23-2017 02:58 AM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 12:41 PM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 03:11 PM
HID question mrlewistan Cosmetic Modification (Interior/Exterior/Lighting) 8 12-31-2012 08:49 AM
mpg question jarviz Scion FR-S / Toyota 86 GT86 General Forum 1 07-10-2012 02:40 PM
