Old 04-07-2018, 09:37 AM   #57
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
If you find the relay setup, 99% of the time you just find the signal wire itself that allows the relay to trigger, and then you just cut it and wire it to a fused wire behind the dash.
Worst case scenario you can buy a 20$ premade harness online and install it yourself.
-B
HeresMyMind is offline   Reply With Quote
Old 04-07-2018, 01:36 PM   #58
WelshJ
Drives: FRS
I want to activate the rear fog triangle on my 13 FRS. I can purchase the light socket and wire harness and run it to either the fuse box or the front fogs. I only want the rear fog to light when the front fogs are on. I think I would prefer to power it from the fuse box if possible but could splice into the fog light itself if that is easier. What do you think? How would you go about it. Thanks in advance.
WelshJ is offline   Reply With Quote
Old 04-07-2018, 02:07 PM   #59
carlovestela
Drives: 2015 Firestorm FRS
$295? I thought i will only change the bulbs.
Maybe ill get spec d and hid.
How about the DRL. Dont like the yellow light
Originally Posted by HeresMyMind View Post
I would highly recommend a HID Projector swap for your OEM halogen projector. They make a kit that is a direct bolt in over at www.theretrofitsource.com.
I would use their morimoto brand if all you wanted to do was swap the bulbs to a HID version. This will increase some brightness but in no where will it be as close to a proper retrofit which wouldnt cost too much more. (125-145$ more in parts).
LED bulbs are really hard to recommend for the highbeams. ever reflector is different and every LED bulb is different the way they position the LEDs on the bulb itself. So what may work for 1 cars headlight well wont work for another. I would just leave the stock bulbs in there.
https://www.theretrofitsource.com/co...C54404%2C48188
295$ for the full retrofit kit, that will give you properly designed projectors for HID bulbs that are a low beam and a highbeam (you would also have your OEM high beams leaving you with 4 highbeams!).
-B
carlovestela is offline   Reply With Quote
Old 04-07-2018, 09:11 PM   #60
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Originally Posted by carlovestela View Post
I have 2015 frs and stock headlights.
Want to put hid for low beams and led for highbeam and drl.
Is that worth it? Bulbs only?
And what brand you recommend?
Thanks
I've used LED for the high beams. I bought some from vled.com. They have LEDs facing out on both sides but you can rotate them to be facing up and down or right and left. They look great as DRLs and actually performed well as high beams.
Sent from my Pixel 2 XL using Tapatalk
Rican_D is offline   Reply With Quote
Old 04-10-2018, 01:22 PM   #61
pcguru2000
pcguru2000's Avatar
Drives: toyota 86 2017
Somewhere on this forum someone mentioned an adjustment wheel inside the cabin, that lets you adjust the headlights up or down. Do you know where that's located?
I know there's adjustments you can do with a screw driver on the headlights themselves. I just can't find the adjustment wheel in the cabin.
(I'm not talking about the cabin light dimmer switch)
pcguru2000 is offline   Reply With Quote
Old 04-10-2018, 01:24 PM   #62
HeresMyMind
These are only found on the BRZ with HIDs. The Fed does not have then. And I’m not sure abou the new LED headlights for BRZs
-B
Old 04-10-2018, 01:25 PM   #63
HeresMyMind
Just adding a HID kit will be about 120-140.
Doing a projector swap and HIDs is 295 which will get you much better results. Even better output than the Spydie lights with HIDs
-B
Old 04-10-2018, 01:48 PM   #64
tobin
tobin's Avatar
Drives: '13 BRZ
I've been trying to do this too for years now. Still waiting for quality DIY instructions.
tobin is offline   Reply With Quote
The Following User Says Thank You to tobin For This Useful Post:
WelshJ (04-10-2018)
Old 04-10-2018, 01:50 PM   #65
HeresMyMind
Do you want them to just trigger off the oem fog light switch?
Do you have to have the rear fog light on your dash?
Do you want a seperate switch to turn them off even if your front fogs are on?
I can draw a very camera basic wire diagram for you on how to do it.
-B
The Following User Says Thank You to HeresMyMind For This Useful Post:
tobin (04-11-2018)
Old 04-10-2018, 01:56 PM   #66
pcguru2000
pcguru2000's Avatar
I don't have fog lights but wonder if the wiring already pre-exists to the red triangle. Anyone know. Before this, I thought the triangle was just a reflector.
Old 04-10-2018, 02:00 PM   #67
HeresMyMind
So you need a few things then.
Oem fog light switch.
6” wire harness that goes from the switch to the wire harness behind the dash
Fog relay
About 25ft of wire
A universal bulb socket
A light to bulb to match said socket.
Install harness / relay / switch in the dash (all plug and play)
Then run 2 wires from the oem fog light plug (taped up under the headlights behind the bumper) all the way to the rear triangle light.
Connect those wires to the universal socket.
Drill a hole in the rear light assembly. Then insert into the triangle.
-B
pcguru2000 (04-13-2018)
Old 04-10-2018, 06:03 PM   #68
WelshJ
Drives: FRS
-B
Triggering off the oem front fog switch would be great.
There is a rear fog indicator on the dash but it ismy understanding it is inoperable.
No need for a separate switch.
I would appreciate any help I can get.
Old 04-10-2018, 07:15 PM   #69
carlovestela
You know how much spec d headlights with HID
-B
Old 04-11-2018, 12:00 PM   #70
tobin
tobin's Avatar
Drives: '13 BRZ
-B
Hey I'm in CT too
Rear fog light on my dash- no I don't care about that. I would like the rear fog bulb to turn on/off with my front fogs using the stalk switch. No separate switch needed. I rarely use my fogs unless it's necessary. A diagram would be great. I've run wires to my backup camera so I'm comfortable doing that. Thanks!
OEM foglight install question DarkSideFRS Cosmetic Modification (Interior/Exterior/Lighting) 3 06-12-2017 04:21 PM
FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides Verge Exterior Parts (Aero, Lighting, Etc.) 12 11-21-2014 09:56 PM
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 02:19 AM
