Old 04-05-2018, 11:58 AM   #15
sid94
Drives: 2013 frs
Originally Posted by jasonojordan View Post
After discovering that you had the injector problem while flowtesting the injectors did you change your plugs to new plugs?
Also I am sure your tuner has already but make sure he has checked the flow tables and that there are no issues there from going from stock to the ID1000 injectors.
I did when I took out plugs to check them after I found injector was stuck open
sid94 is offline   Reply With Quote
The Following User Says Thank You to sid94 For This Useful Post:
jasonojordan (04-05-2018)
Old 04-05-2018, 12:39 PM   #16
FRS Justin
Drives: 2013 Asphalt FRS
BINGO stock setting on injectors with 1000id will definitely cause this.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 04-05-2018, 01:11 PM   #17
sid94
Drives: 2013 frs
I’ll ask James and see if he set it right and send him whatever kind of log I can
Old 04-05-2018, 02:59 PM   #18
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I'm sorry I thought I came to the understanding that you already had your new Port injectors scaled. Ya you can't just replace injectors with bigger 1s thinking they are drop in ready. If you have the Racerom add-on with your ecutek cal the injector CC setting is easy to adjust but James a good guy and he should be able to correct this with a few logs.
James left my tune unlocked so I just make my own minor changes now.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-05-2018, 03:24 PM   #19
sid94
Drives: 2013 frs
He sent me a base tune for my setup with those injectors and all. If that’s what you mean by scaled then yes they are. As for James super cool he’s been answering all questions he can but he’s just tuner so I don’t wanna bug him much. Says I was the first DI injector he’s ever seen stay stuck open lol
Old 04-05-2018, 03:57 PM   #20
FRS Justin
so you replaced one DI injector or the set? Their
are different injectors.
710whp
Old 04-05-2018, 04:06 PM   #21
sid94
Drives: 2013 frs
so you replaced one DI injector or the set? There are different injectors.
Just one made sure part number was the same along with the same big number stamped on the injector body when I received said injector
FRS Justin (04-05-2018)
Old 04-05-2018, 08:34 PM   #22
sid94
Drives: 2013 frs
So I swapped plugs from back of the head to the front and then they switch cylinder 4 came back sooty like if it had combustion and cylinder 2 came back washed out with fuel. I checked my coils to see if I can see any cracks or obvious signs of failure and only this I can see is there’s a white something in all the connectors
[MENTION=147476]
@FRS Justin coils would normally throw a code but what if it doesn’t run long enough to register a misfire code??
Old 04-05-2018, 09:18 PM   #23
FRS Justin
that's a grease to keep connections from corroding
710whp
Old 04-05-2018, 09:22 PM   #24
sid94
Drives: 2013 frs
Ok, any way to check coils? Besides putting screw driver in it and cranking?
Old 04-05-2018, 09:29 PM   #25
wbradley
Sarcastic SOB
wbradley's Avatar
Dialectric grease.
Maybe a multimeter to test the coils firing?
Old 04-05-2018, 11:45 PM   #26
sid94
Drives: 2013 frs
Originally Posted by wbradley View Post
Dialectric grease.
According to the service manual these coils can’t be resistance checked to determine wether good or bad. That was my first idea but it didn’t quite work out for me
Old 04-06-2018, 01:14 AM   #27
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Can’t you check for spark by pulling the coil, pulling the spark plug and inserting it in the coil? Turn the engine over and see if you are getting spark. If not then swap spark plugs or swap a new plug and continue to isolate a plug problem versus a coil problem. Seems like if you have compression and if you have fueling confirmed (pressure, delivery and tune) then this is a spark issue.
Seems like if it was a MAF issue then every cylinder would be bad. Same if it was a fuel regulator or any other component that is not cylinder specific.
Old 04-06-2018, 01:17 AM   #28
wbradley
Sarcastic SOB
wbradley's Avatar
The normal procedure to determine a faulty coil when tuned. Can you flash to a base tune and see what faults it gets on an OBD2?
Or mechanically the coil outputs could be measured with probes for current or voltage, multimeter is useful if you know what you're looking for.
Fuel, ignition, mechanical. Did you leave a rag in the inlet? Piss in the fuel tank?
Building the engine for 400+hp Dogster70 Forced Induction 20 07-16-2017 10:59 AM
New motor - starting issue protpibe Engine Swaps 24 06-01-2015 01:01 AM
Starting issue? winsometang Issues | Warranty | Recalls / TSB 7 11-26-2014 06:25 PM
Starting issue Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 33 08-15-2013 08:40 AM
Van starting issue-need advice. LivingLegend Off-Topic Lounge [WARNING: NO POLITICS] 3 01-15-2013 11:48 PM
