Old 03-28-2018, 08:31 AM   #239
steve99
Drives: FT86
@KDad2 here is def for A00D rom with P0420, just unzip
read romraider tips link below
http://www.ft86club.com/forums/showthread.php?t=79152
File Type: zip OFT V4 Auto 2012-2016 base is A10I as A00D.zip (40.6 KB, 89 views)
The Following 2 Users Say Thank You to steve99 For This Useful Post:
KDad2 (03-28-2018), Teseo (03-29-2018)
Old 03-29-2018, 05:56 PM   #240
robzz
Drives: Brz
Just flashed the V4. Got weird bucking problem at low engine load just after startup. I did'nt reflash the previous V2 rom yet but if anyone can take a look at my log. Here's my analysis so far
- It shows -29 STFT but as soon as I touch the throttle pedal (2%), STFT jumps straight to 0 and AFR drops to 11.25.
- It changes from Fuel System Status 2 to 4 as soon as I give any throttle. 2% throttle normally won't change to Closed loop
- The problem will resolve itself when the car heats up a little bit but I can't get any power from the engine while it's doing that.
- The problem is reproducible. It did not do it on 1st start after flash but after 3-4 runs. Now it does it pretty much every time the engine is cooled down.
- AFR tend to stay at 11.25 for much too long. When bucking lessens, the AFR stays near for a couple minutes. It looks like it comes back to regular values as coolant heats up.
- When coolant is up to 160°F, all seems pretty normal
Can it be the upstream O2 sensor that's going bad?
https://datazap.me/u/robzz/16-v4-02c
Thanks!
robzz is offline   Reply With Quote
Old 03-29-2018, 07:00 PM   #241
stlgrym3
Noobie question, once the tablet is married to your car, you do not need to perform the READ process again right? if i need to update the stage1 flash to a stage2 all i have to do is connect the tablet and do the WRITE operation of the appropriate tune file, correct?
stlgrym3 is offline   Reply With Quote
Old 03-29-2018, 07:21 PM   #242
bababooey
Drives: BRZ SWP Limited -6MT
correct, once it read the stock that info stays on device. when time comes you can go straight from stg 1 > stg 2 / 2+ / e85 depending on hardware & fueling.
bababooey is offline   Reply With Quote
The Following User Says Thank You to bababooey For This Useful Post:
stlgrym3 (03-29-2018)
Old 03-29-2018, 08:13 PM   #243
natedawg239
Drives: 2017 Subaru BRZ Limited PP
Got a 17 brz with mxp sp exhaust and jdl front/mid pipe and have the v4 installed. Felt good at first but seems like my car is feeling sluggish now. Even just put in e85 for the first time and car doesn’t feel much faster. Any ideas why?
natedawg239 is offline   Reply With Quote
Old 03-29-2018, 08:45 PM   #244
Teseo
Drives: frs
Let ecu to learn new parameters
Old 03-29-2018, 08:49 PM   #245
stlgrym3
saw Shiv updated the OFT download page with the new v4.02 stage files. i wonder if those support K00D (2017 AT)? i emailed him already waiting for reply.
Old 03-29-2018, 11:48 PM   #246
John27
Drives: scion fr-s
does any one know if where any changes from 4.01 to 4.02 tune ?
John27 is offline   Reply With Quote
Old 03-30-2018, 12:03 AM   #247
stlgrym3
i emailed Shiv if the new version contains tunes for k00d, waiting for him to confirm
Old 03-30-2018, 12:12 AM   #248
Teseo
Drives: frs
Same tune, just added some cal id
Old 03-30-2018, 04:41 AM   #249
ctmandu
ctmandu's Avatar
Drives: 2017 860
loaded OFT stage one tune on my 2017 860 and all is good . CAL was K00C
2017 Toyota 860
ctmandu is offline   Reply With Quote
Old 03-30-2018, 10:46 AM   #250
BTXP.XD
Drives: 14' FRS
Anyone can convert that to a .bin file for me, in need of stg 2+ tune... rom raider won't install for me.
anyone every has this problem with rom raider? just got a blank installation screen where it supposed the desktop shortcut option.
NBeyond
https://www.instagram.com/nbeyond__/
Support us for daily cars + upcoming clothing line.
BTXP.XD is offline   Reply With Quote
Old 03-30-2018, 10:52 AM   #251
ermax
ermax's Avatar
Yeah RomRaider can be a pain to install sometimes. Try downloading the Zip version without the installer from here:
http://assembla.com/spaces/romraider...C3-windows.zip
Then just extract it where ever you want and then double click on RomRaider.jar. This assumes you have JRE installed already.
Old 03-30-2018, 02:00 PM   #252
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Thanks!
What tune did you have on before? What mods do you have installed? Is this a new problem or did you have it before flashing to the v4 tune? Exactly which tune did you flash on?
guybo is offline   Reply With Quote
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
