| Software Tuning Discuss all software tuning topics. |
Drives: 2015 Subaru BRZ
OFT log - adv multiplier = 0
Hello,
I recently got a OFT and flashed my ECU with stage 2 EL tune file. I did 2 third gear pull yesterday and logged them. When I see my log files, the adv multiplier is always 0. I have 2 questions. 1) adv multiplier = IAM ? 2) adv multiplier = 0, is that normal? |
#2 | |
The Dictater
Drives: '13 Red Scion FRS
2) No. Likely a mistake in the logging. If you flash your ecu again does it start at 1 or .7? If so, your ECU is detecting a lot of knock and reducing timing (logging good, engine bad). If after flashing the adv multiplier starts at 0, then you definitely have a logging issue (logging bad, engine ???). Hope that helps. |
| The Following User Says Thank You to Spuds For This Useful Post: | Boomerang (03-29-2018) |
#3 | |
86
logging issue, what is your CAL ID? |
#4 |
#5 | |
Thanks, so you suggest me to flash my ecu again, then to log afterwards to see if this value starts with 0.7 or 1?
#6 |
The Dictater
Yes, that will determine if you actually have a logging problem or some other problem. I think it will start at 0, which means you have a logging problem.
#7 |
Spuds, I flashed again the tune and run diagnostic again, adv multiplier is still 0. But I run diagnostic on my friend's car (2013 BRZ), it shows adv multiplier 1.
| The Following User Says Thank You to madcatjf For This Useful Post: | Spuds (04-01-2018) |
#8 | |
Drives: FT86
Your friends car may ne different calibration id . If iam is 0 and car is driving ok its definitely logging problem. |
| The Following User Says Thank You to steve99 For This Useful Post: | Spuds (04-01-2018) |
#9 | ||
The Dictater
As steve99 said, that proves that the CALID for your car is not logging advance multiplier correctly. CALID is usually different between model years, so that is why your friend's car is logging correctly. (I didn't think that was clear when steve99 said it Fixing it requires a software update to the tablet. You might want to try and contact Openflash with what you found. |
#10 |
#11 | |
Drives: FT86
each calid will require different ecu logging ram addresses. You will have used correct file, oft wont load incompatable tunes (unless you do a bit of hacking). Shive will likely send you one of the new V4 tunes for your calid this will correct the logging issues |
#12 |
Steve99, when I flashed my car, I used the file "Stg2 EL A03N" which Shiv sent me. I am from China and the CAL ID of my car is ZA1JA03N. I am afraid that there is no V4 tune file for my region.
#13 |
Drives: FRS Hot Lava
Thanks to this post I learnt about logging issues. I have exactly same problem.
I updated the OpenFlash Manager. Uploaded latest OTS Maps. Re flashed with new map. Problem solved. Logging correctly. |
#14 |
Drives: Subaru BRZ 2016
Hi, new member here!
I am experiencing a similar issue with ZA1JF00C. Some parameters do not log properly. For example, VVTi is all over the place and IAM is always 0. Also, when I load my base tune file in RomRaider using the .xml definition file that OFT supplied to me all I get is errors. I found a .xml definition file on the RomRaider forum that works perfectly with my base tune file, and I can see all the maps correctly. I am reluctant to troubleshoot by loading a tune I received from OFT into my car as the map addresses are clearly different than in my original tune. So aside from the fix described above, does anyone have a suggestion? My OpenFlash Manager completed all the automatic updates. |
| F20P adv multiplier=0 | pym19109 | Software Tuning | 2 | 03-29-2017 07:53 AM |
| advance multiplier = 0 why???? | agent47 | Software Tuning | 11 | 01-29-2015 12:11 AM |
| OFT manager v1.31 ADV Multiplier at 0 | DarkestBuddha | Software Tuning | 7 | 11-07-2014 03:13 PM |
| Advanced Multiplier??? What is it? | UrmyboyBLUE | Software Tuning | 8 | 10-13-2014 10:05 PM |
| Displaying the Adv Multiplier | sw20kosh | Software Tuning | 12 | 12-09-2013 11:42 PM |
