Old 03-23-2018, 05:42 PM   #1079
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by JakeRogue View Post
How big a deal is this end link thing?
Depends on the climate, I took my OE off after ~3 years of not being touched and driven year round for ~45k miles, zero issues, California climate.
Originally Posted by BoxCarRacer View Post
The rear endlinks are at a pretty ridiculously lousy angle. I had called Eibach about it and they say that they are FINE. All that accomplished is make me think Eibach is a little more clueless than they let on.
The more suspension companies you talk to, the more research you end up DIY'ing... which is my polite way of saying I don't trust any of 'em.
And that's not to say they're all crap, it's just whatever they sell comes with caveats that aren't always obvious.
ineedyourdiddly
Old 03-23-2018, 11:22 PM   #1080
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
This is an example of how a qualified race shop can help you: less BS, not wedded to any particular producer, focused on data and facts gleaned from decades of real-world experience, etc., etc.
The race shop I've favored in the past will use appropriate parts, from any manufacturer/producer/supplier, and the shop charges their cost + 10% for those parts. The focus is on making you and the car faster, and not milking you like a worn-out cow ready for the glue factory.
Always spend your hard-earned money wisely, and take the claims of manufacturers with at least a grain of salt. As to the latter point, I've found Essex Parts' expositions on brake kits and their components to be among the best available online. Would that every manufacturer could, and would(!), provide facts and data in as in-depth a manner as EP does. Full disclosure: I've reviewed an EP kit (for another platform, and with no punches pulled), and received a 19% discount on that kit for doing so.
dradernh is offline   Reply With Quote
Old 03-24-2018, 11:28 AM   #1081
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Got snow, roadsalt or salty humid air?
--kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
Old 03-24-2018, 11:30 AM   #1082
M0nk3y
My god. I’m surprised CS and DS twins didn’t bitch about this issue.
And you wonder why people make fun of SSC
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
G_Ride (03-24-2018)
Old 03-24-2018, 11:50 AM   #1083
cjd
cjd's Avatar
Drives: 2017 BRZ
To be fair, I think it's mostly the rear swaybar links I hear the most noise about, and most people didn't have adjustable bars there before. The car was also not lowered at all.
Those two things change things slightly... at least as far as people worried about stress on the endlinks.
As for ease of removal, yeah. That hasn't changed. It's no better, in my experience, with aftermarket. So on the whole, I'm still just as surprised as you are.
Old 03-24-2018, 12:19 PM   #1084
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
The street classes can change endlinks along with their swaybar. SSC is the only class that doesn't allow you to change endlinks when you change your swaybar.
Street has to keep the stock endlinks with the stock bar for whichever they don't change, but if you aren't swapping an endlink it doesn't matter if it is too rusty to remove.
14stu is offline   Reply With Quote
The Following 2 Users Say Thank You to 14stu For This Useful Post:
DaWorstPlaya (03-26-2018), strat61caster (03-24-2018)
Old 03-24-2018, 12:30 PM   #1085
jorober5
Drives: 2015 FR-S
To be fair, in two national events, I've heard very little complaints from the people competing in the class.
The philosophy from SCCA on this is to take a "wait and see" attitude before allowing aftermarket endlinks. If the links aren't actually needed, then they don't want to raise the price of entry. *IF* they start breaking then the allowance will be made. I asked about a spare because I thought a $25 insurance policy was cheap and easy.
We all agree that the setup isn't optimal but we are all on the same setup. If you get frustrated about fixing setup issues one at at time I'm guessing STX is more for you. If you want to put the kit on and drive, come on out! I'll see you in Blytheville :-)
Jonathan
#21 SSC
jorober5 is offline   Reply With Quote
Old 03-24-2018, 02:39 PM   #1086
chkltcow
Drives: 2013 FRS White w/ cone marks
Well at least they fixed some peoples' biggest complaints and the stickers are no longer blue. WHEW... glad to see that change pushed through.
chkltcow is offline   Reply With Quote
Old 03-24-2018, 09:27 PM   #1087
Imp
Bring out your dead
The way I look at it is most non temperate climates will have to replace them anyways when doing the job. I'd rather have used that money towards good ones than oem replacement that will have the same issues.
--kC
Old 03-25-2018, 02:16 AM   #1088
tony_r
tony_r's Avatar
Drives: '15 STX
If you're using soft on the rear sway you're doing it wrong anyway. It's no big deal.
tony_r is offline   Reply With Quote
Old 03-25-2018, 09:02 AM   #1089
jorober5
Drives: 2015 FR-S
With the show you are putting on out in Fontana I don't think anyone will argue with you on setup I'm assuming this means you are also on stiff for the front bar?
Old 03-25-2018, 09:31 AM   #1090
tony_r
tony_r's Avatar
Drives: '15 STX
Haha, thanks. At soft/hard, full stiff shocks. Works well at this site, probably at other lower grip asphalt lots as well. Rear toe is a big deal on these cars, going from 1/8" total in to 1/4" made a very noticeable difference in stability.
Old 03-25-2018, 12:59 PM   #1091
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
I've been waiting for someone else to say this. Second data point: The winning car at the Ft. Meyers Pro had the both bars set to stiff.
Briankbot is offline   Reply With Quote
Old 03-25-2018, 06:18 PM   #1092
jorober5
Drives: 2015 FR-S
While that's a useful data point, the fastest car on the left course in Ft. Myers (me) had both bars on soft. I couldn't get it done on the right and ended up third. It will be interesting to see where everyone ends up but I'm not sure there is a definitive answer just yet. It could be course and/or driving style dependent, or it could end up being clear, but I'm not sure we know *for sure* just yet. It appears Tony is well ahead of the curve on testing so he may feel there *is* a definitive answer!
The Following 2 Users Say Thank You to jorober5 For This Useful Post:
chkltcow (03-25-2018), Twinz (03-25-2018)
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 02:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 10:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 12:20 PM
