Old 02-03-2018, 09:10 PM   #1
fibber1200
Drives: scion frs 2013
monogram headlight install help needed
i had a 2013 frs and looking to install a 2016 Scion FR-S Release Series 2.0 headlight on my car i had try to look up few posts about the wiring, but they dont have picture, im not confidence to do it.
is that anyone know where i can get that 6 pins to 8 pins harness to plug and play on my car? or any video or picture to picture guide may be help too.\
thanks
fibber1200 is offline   Reply With Quote
Old 03-16-2018, 01:31 AM   #2
mikeyvaj
Drives:
thanks
Have you figure it out? I'm doing the same thing but no one seems to know how.
Sent from my SM-N950U using Tapatalk
mikeyvaj is offline   Reply With Quote
Old 03-16-2018, 03:08 AM   #3
Brayden_23
Drives: Asphalt 2015 FRS
Follow this thread: http://www.ft86club.com/forums/showthread.php?p=1012406
When it comes to wiring the white wire for DRL, tap into the resistor positive so it will come on as DRL. Otherwise if you leave it in the plug, the LED strip will be on all the time at full power and blind others at night.
Brayden_23 is offline   Reply With Quote
Old 03-17-2018, 01:21 AM   #4
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
I've just swapped out my base headlights for the Monogram/RS lights. Most of the steps you see online are for the JDM headlights which are 8-pin connectors with 7 active leads (pins). The US RS lights are also 8-pin connector but with 6 active leads.
To answer your question, you will re-use (or buy new from Toyota/Subaru) the 6-pin connector from your base headlights.
This is the pin-out for the 6-pin connector that you will re-pin to your RS headlights...
---- TAB ----
| 3 | 2 | 1 |
| 6 | 5 | 4 |
1 = yellow - high beam +
2 = black (thicc) - headlight gnd
3 = red (thicc) - headlight +
4 = blue - high beam gnd
5 = black - led gnd
6 = white - led +
Alternatively, you can tap the DRL from the resistor (steps found on the JDM headlight install).
iLuveKetchup is offline   Reply With Quote
Old 03-19-2018, 11:31 AM   #5
mikeyvaj
Drives:
So I install everything but the drl is still coming in even after the lights are turned on. I'm assuming one of the ground is wrong?? I also wired the custom wire to the 12v from the resistor.
Old 03-19-2018, 11:45 AM   #6
iLuveKetchup
Drives: EFF JAY
From the looks of it, you have pin 6 connected to parking + lead. If you want the headlight LEDs as a DRL like OEM RS/Monogram, you have to connect the resistor + to pin 6 on the headlight connector.
Old 03-19-2018, 11:49 AM   #7
mikeyvaj
Drives:
Hmm.. I'm wondering how I will do that. I currently have a wire hooked up to the 12v green resistor wire atm.
Old 03-19-2018, 11:51 AM   #8
iLuveKetchup
Drives: EFF JAY
You either have power coming from the resistor + or the parking +. From photo #2, do you have both power sources connected to pin 6??
Old 03-19-2018, 11:54 AM   #9
mikeyvaj
Drives:
They are both on pin 6.
Old 03-19-2018, 11:57 AM   #10
iLuveKetchup
Drives: EFF JAY
It should be one or the other. Things go bad when there are two power sources on the same circuit.
Old 03-19-2018, 11:58 AM   #11
mikeyvaj
Drives:
It's weird because whwn I took it off. The drl is still lighting when the headlights turn on. I'll go ahead and take the wire out
Old 03-19-2018, 12:21 PM   #12
mikeyvaj
Drives:
So there's no need for the white wire from the monogram/rs to be plugged into the 6pin connector? Since I'm using the 12v resistor wire.
Old 03-19-2018, 12:24 PM   #13
iLuveKetchup
Drives: EFF JAY
That's right.
Old 03-19-2018, 12:26 PM   #14
mikeyvaj
Drives:
That's right.
Man that's hard to do. The resistor wire is so short. I'll work it out. Thanks for the help!
Series 10/Monogram headlight install rokius Southwest 10 03-16-2018 10:17 AM
Series 10 Monogram Headlight Swap to 13-16 FR-S... NAEightySix Cosmetic Modification (Interior/Exterior/Lighting) 2 05-05-2017 11:49 AM
wtb headlight for monogram or release serie snowman Canada Classifieds 2 01-03-2016 09:29 AM
wtb: FRS Driver Side headlight Monogram Edition HID oem sokol Want-To-Buy Requests 0 07-18-2015 02:39 AM
Monogram headlight issues Simon Cosmetic Modification (Interior/Exterior/Lighting) 8 10-28-2014 11:48 AM
