BRZ AC Rattle?
New to the forums!
I found some stuff that were related to my issue when I used the "Search" feature. But most of them described a chirp or flapping noise. This is a definite rattle noise. only happens with the AC on. Any help is appreciated. |
#2 | |
![]() What engine mods do you have ..?? Does it sound like the sound is coming from the compressor ..?? So, it doesn't make the sound if the compressor clutch is NOT engaged .. ?? Is the system cooling OK ..?? Come back. humfrz |
#3 | |
It sounds like it's coming from the vibration of the pulley in the video. Cooling system is fine. Yeah there is no sound when AC is off. |
#4 | |
However, the idler pulley could be bad. If you loosen it up, does it spin free and doesn't wobble ..?? Can you get rod to touch the compressor (with your ear next to the other end) to see of the sound is coming from the locked compressor .. ?? Have you checked to make sure the compressor is bolted on tight ..?? It could be that the clutch on the compressor is damaged and making the compressor unit rattle when it engages. I'll ring up ol @Ultramaroon ...... for an opinion.....he has good ears ..... ![]() Stay tuned. humfrz |
#5 | |
#6 |
#7 | |
I think it might have something to do with the idler pulley? |
#8 | |
If you suspect the idler pulley, I'd suggest you loosen the belt and see if the pulley spins freely and doesn't wobble on the shaft. @Ultramaroon is LATE to this party ..... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (03-13-2018) |
#9 |
It's just the gearbox. All the gears rotate whenever the input shaft spins. When the engine spins slowly, the firing pulses cause the gears to rattle a little.
The AC increases the load on the engine at idle so you get more of the rattle. Normal.
#10 | |
#11 |
Drives: frs
And when you press the clutch all the way down the noise disappears?
#12 |
Yup. Ever heard it? It's more obvious when it's really cold.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Teseo (03-13-2018) |
#13 |
Drives: frs
| The Following User Says Thank You to Teseo For This Useful Post: | Ultramaroon (03-13-2018) |
#14 |
Thanks for all the responses guys. Still getting used to the small quirks of the car.
Reminds me of my MR2 where I used to hear all the clicks, clunks, and squeeks of it all around. |
| Kartboy rattle? | Venator | Engine, Exhaust, Transmission | 37 | 09-14-2014 06:53 PM |
| Anyone else's 6MT a rattle box at low RPM? | Silver Ignition | Scion FR-S / Toyota 86 GT86 General Forum | 81 | 05-30-2014 12:56 AM |
| Rattle above 5k rpm | trippinbillies40 | Issues | Warranty | Recalls / TSB | 1 | 05-28-2014 03:55 PM |
| AC Rattle | AVodka14 | Issues | Warranty | Recalls / TSB | 8 | 05-21-2014 01:08 PM |
| A/C Rattle? | djliquidsteele | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-17-2012 08:46 PM |
