| Software Tuning Discuss all software tuning topics. |
Drives: 2013 Scion FRS manual
Car won't move while in gear after open flash stage 1 tune.
This may be an easy fix but i'm having trouble with tuning. Stage one tune and original tune loads up to the ECU great. The only problem I have is when I get ready to drive, the car doesn't go anywhere. Like the tires are locked or something. I let the car idle for the 45 secs after flashing. And I have done this before to another car, different tablet, but had zero problems driving after flashing. How do I fix this?? Any advice would help, thanks!
#2 |
Take the parking brake off.
#3 |
The Dictater
Drives: '13 Red Scion FRS
1. Does the car sound funny or messed up at idle?
2. If not, does the engine rev when you press the throttle? 3. If so has it been still for a few days? Possibly after having wet brakes? 4. If the car is on flat ground, does it roll in neutral with the parking brake off? Don't do this on a hill. 5. Have you done any work to the car recently? Fyi, none of these are troubleshooting the ECU. The ecu would not cause a locking of the wheels. Likely your brake pads/shoes are just stuck to the rotors/drums. |
| The Following User Says Thank You to Spuds For This Useful Post: | steve99 (03-12-2018) |
#4 |
Drives: 2013 Asphalt FRS
flash a auto tune in a auto car not a 5sp tune
following
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#5 |
Drives: UK GT86
Sig states manual car. Reckon the tune has locked the brakes up....
In all seriousness though, have you had rain/ice recently OP?
.: Stealth 86 :.
#6 | |
#7 |
No Rain or ice either.
#8 |
The Gunshine State
Drives: '14 BRZ Limited
This doesn't make any sense.
Is the clutch fried? Calipers seized on the rotors? Forgot a wheel chock?
![]() Current DD: M235i |
| The Following User Says Thank You to 8RZ For This Useful Post: | wparsons (03-13-2018) |
#9 |
The ECU tune doesn't touch the ABS system, and if it was holding the brakes on you'd hear it pump up the pressure.
Does it roll in neutral with the engine off?
#11 |
Drives: 2013 frs red
My car wouldn't move in gear before the tune.
#12 |
#13 |
Huge E85 fan!
Drives: 2016 Scion FRS
engine off, in Neutral, no E-Brake- will it roll if you push it?
engine On, in Neutral, no e-brake- will it roll if you push it? First thing to figure out is what it is that is keeping it from going. Is it brakes being stuck, stuck e-brake, or will it roll but gears won't engage. Your post is pretty vague. |
#14 |
Badass Member
Drives: 2014 SWP BRZ Limited
I am baffled on some of these posts.
following this though. |
| Open Flash Tune for NA Catless Setup | neroman98 | Software Tuning | 4 | 09-03-2017 09:27 PM |
| Open Flash Tablet stage 1 or UEL 2? | donkeysgt86 | Software Tuning | 0 | 12-07-2016 05:24 PM |
| I bought Tomei Headers and have OFT. Do I just flash the Stage 2 Tune? | GT86 Guy | Software Tuning | 3 | 08-06-2016 07:44 PM |
| Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 09:15 PM |
