Old 03-12-2018, 09:52 AM   #1
tomm.brz
Drives: brz 2017 hksv2
Cam timings and AFR shortly after start-up
Hi guys,
in my ecutek tune I noticed that after starting up the engine (when cold start just make it for longer but also warmish start is doing it)
fuel system ststus =1 lasts only few seconds, then goes to closed loop and AFR and cam timings go to values in this log:
https://datazap.me/u/tommbrz/definit...=6-14-28-30-31
AFR Target and Actual goes to 15.10 and Cam intake and exhaust to 2 / -4
After 2 minutes goes finally to open loop idle with correct AFR as tables dictate, 14.7 and cam timings both to 0
Then after all is warmed up goes back to the correct closed loop mode and everything is as expected
Why do I get afr of 15.10 when the car is super cold when actually should be made richer by the maf offset? also dont understand the 2/-4 cam timings
Thanks
Old 03-12-2018, 10:19 AM   #2
steve99
Drives: FT86
02 sensors don't read reliably till they get up to operating temperature and they actually have a heater to assist warmup.
Have a look at the "fuel quantity Total" parameter at the start fuel quantity is 17 and the AFR is 15, yet later on the Fuel quantity is 12 and afr is 14.5. yes the rpm has come down say 10% but the fuel quantity has reduced by around 30% yet AFR is richer. the whole time the fuel quantitly is getting less yet afr is getting richer. Seems to suggest the 02 sensor isn't reading correctly at the start probably not up to temp yet.
no idea why the target afr would be 15, but it starts to ramp down , have to ask Subaru/Toyota engineers, thiers lots of offsets and compensations applied at idle and at cold start. likely lots of stuff no one has bothered to reverse engineer the logic or find the control tables
gather this was cold startup
the cams are not active at idle, the small movements of 2 or 4 degrees are fairly insignificant and probably just within the sensor/actuator tolerances . or the ecu is calibrating/checking don't really know.
tomm.brz (03-12-2018)
Old 03-12-2018, 10:29 AM   #3
tomm.brz
Ok for the afr, makes me more comfortable
the cam settings if I put stock tune, they are fixed at 0 the whole time
The cam timings maps are nothing extraordinary, they are just copypasted from stage2 uel ots rom
Old 03-12-2018, 10:48 AM   #4
tomm.brz
Nope, just triee again a stock tune, its doing the same both afr and cam
thanks Steve
Car won't start. Limited with push to start. uEih Issues | Warranty | Recalls / TSB 22 01-06-2017 11:54 AM
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 09:57 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
