Old 03-10-2018, 02:07 PM   #1
gkanga
Drives: 2014 FRS
Car starts and dies immediately. P0171 (too lean)
Hi guys, I'm hoping somebody has some advice on my issue.
Basic background: 2014 FRS, totally stock. Around 55,000 miles. ~8 month old battery. No issues previously.
I drove the car home from work on Thursday, got gas near my office (93 octane of course), drove the rest of the way home (~20 miles) and everything was totally normal. I didn't drive anywhere yesterday.
Half an hour ago I hopped in the car to go somewhere. It cranked fine, started for an instant then it sputtered out and died. I tried a couple more times with similar results. Once it hung on a little longer and the engine sounded really rough and the car started shaking before dying.
I plugged in my OBDII reader and got one Pending Fault code P0171: Powertrain System too lean (Bank 1).
Searching around it looks like a lot of people getting this error code have custom tunings or forced induction, which isn't the case for me.
Any ideas? Anybody seen anything similar?
gkanga is offline   Reply With Quote
Old 03-10-2018, 03:05 PM   #2
What does the maf look like? What were the last few things you touched under the hood?
https://demos.starbase7.net/t3Portal...00WC30M6X.html
humfrz (03-10-2018)
Old 03-10-2018, 03:17 PM   #3
gkanga
Drives: 2014 FRS
I checked the MAF sensor, qualitatively it looks ok. It's clean, not clogged up with any junk.
Nothing has been touched under the hood very recently. I bled the brakes in September, and replaced the battery and oil change a little before that. I replaced the air filter around the same time, I don't remember exactly when.
Thanks for the link, good info.
The Following User Says Thank You to gkanga For This Useful Post:
Ultramaroon (03-10-2018)
Old 03-10-2018, 03:26 PM   #4
Look for the least exotic shit and work your way down. Good luck.
humfrz (03-10-2018)
Old 03-10-2018, 03:35 PM   #5
Yep, ....... I reckon I'd check the PCV connections and if all looks good, then clean the MAF thing.
PS......Bubba says to unplug the battery then wait 23 seconds and plug it back in ......he has no idea why he suggests that ......
Old 03-10-2018, 03:42 PM   #6
HOW TO PROCEED WITH TROUBLESHOOTING
DIAGNOSTIC CODE TROUBLE CHART
Old 03-10-2018, 10:05 PM   #7
gkanga
Drives: 2014 FRS
Cleaned the MAF sensor, didn't do anything.
We were able to keep the engine alive for a few seconds with starter spray which would seem to indicate it's not a spark plug problem. Combined with the "too lean" error code it points to a fuel delivery problem.
We can hear the pump priming (or doing something) when the key is turned so presumably that is ok.
Took the fuel pump/filter assembly out and looked at it. The filter embedded in the plastic sleeve is brownish looking, I don't know if that's normal. The mesh thing below the pump is also pretty brown (see pic below). Looking at some pictures and videos other people's look white, but maybe that's just when they're brand new.
Old 03-10-2018, 10:18 PM   #8
gkanga
Drives: 2014 FRS
Do these cars have an inline fuel filter or just the one in the tank?
Old 03-11-2018, 12:23 AM   #9
Just that one in the tank. It's not the fuel filter. Clogged fuel filter causes starvation at higher fuel demand, not idle.
humfrz (03-11-2018)
Old 03-11-2018, 03:06 AM   #10
Ragin Gti
Drives: '15 Subaru BRZ
You got gas and then the car wouldn't start. I'd pump the tank out and put 5 gallons of fuel from a different station in it. Bad fuel can absolutely cause P0171. Unless the air intake is completely removed post MAF the engine would still run.
Ragin Gti is offline   Reply With Quote
Old 03-11-2018, 06:44 AM   #11
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I'd like to hear it cranking and not starting. Post a video
guybo is offline   Reply With Quote
Old 03-11-2018, 02:42 PM   #12
gkanga
Drives: 2014 FRS
That does seem like potentially the simplest problem.
Old 03-11-2018, 02:43 PM   #13
gkanga
Drives: 2014 FRS
The audio isn't very good, I will get somebody to help me record a better one.
Old 03-12-2018, 06:04 AM   #14
guybo
Huge E85 fan!
guybo's Avatar
OK, so you have compression. Some security systems will kill fuel, that's what it sounds like. But that's a guess, you need to find out if it's not getting spark or not getting fuel and work your way back
p0171
Lean engine codes p0171 zackegle Issues | Warranty | Recalls / TSB 23 03-14-2022 01:17 PM
Lean condition after Treadstone install. p0171 ejkiet Forced Induction 20 07-14-2017 11:42 AM
too lean issue? p117B p0171 engine codes zackegle Issues | Warranty | Recalls / TSB 1 03-21-2017 09:03 PM
Car dies immediately Snyperiflex Issues | Warranty | Recalls / TSB 6 02-08-2016 03:24 PM
Electric dies when trying to start, disconnect/reconnect battery starts fine gregdobs Issues | Warranty | Recalls / TSB 10 05-12-2015 11:37 AM
