Old 03-08-2018, 06:45 AM   #1
Tomita San
Tomita San's Avatar
Drives: Scion FR-S
Romraider OF defs for A00C
Wanted to take a look/modify the SBD turbo bin (downloaded from here) with Romraider. My original calid is A00C.
Unfortunately i can not find the xml RR definition for this OF bin (A00C).
The zip file downloaded from the OFT site does not contain it..
On the side note, checked the bin with hex editor and it appears to be based on A01C - the first 2 strings A00C the 3rd A01C.
Does this turbo map have the DI seal issue fix?
Tomita San is offline   Reply With Quote
Old 03-08-2018, 02:24 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You will likely need to email Shiv for a file. There is an A00C in the US 6mt file. I don't know how useful that is to you being out of region.
Old 03-09-2018, 01:29 AM   #3
steve99
Drives: FT86
OK if first two calid strings are A00C (8000,10000 hex) and third around 11000 hex is A01C then rom is based on A01C. and just calid hacked to A00C so oft will load.
Grab a A01C def and mod it to be A00C (change the two strings internally in def from A01C to A00C) and you should be good to open in romraider.
Check tables carefully if anything weird STOP
note if you downloaded the rom from this forum it will likely be for the very early low boost sbd kits like 7psi, so its not suitable for the newer kits that run higher boost
A01C rom have DI seal fix
Old 03-09-2018, 09:15 AM   #4
Tomita San
Tomita San's Avatar
Drives: Scion FR-S
Thanks for the reply. The problem is, in the actual zip file there is no A00C xml either..in fact i have not found any xxxC def for RR..can i use other def to change it?
There is however A00C for the OFT..
Old 03-09-2018, 09:24 AM   #5
steve99
Drives: FT86
You dont need A00C def you need to get a true A01C def and make those alterations
The oft A00C or A01C defs are likely B01C based depending on oft tune revision V1 V2or V3
A01C def here
https://github.com/TD-D/SubaruDefs/t.../RomRaider/ecu
If you not sure dont edit the rom pr flash it , can brick ecu
Old 03-09-2018, 05:43 PM   #6
Tomita San
Tomita San's Avatar
Drives: Scion FR-S
A01C def here
Sorry for beeing cunfusing, by A00C in the last sentence i meant the def for the OFT not Romraider.
Thanks for the link. I take that A01C and make those changes (for RR) and for the tablet i take the available A00C from the zip file. Is that right?
Btw.i plan to run 0.5bar only, so the map should be good for my needs.
Old 03-09-2018, 07:41 PM   #7
steve99
Drives: FT86
Yes that should work, but carefulky check tables if you notice any weird values, corrupted characters, blabk tables ,stop the rom and def are mismatched
Tomita San (03-16-2018)
romraider defs for flex fuel... Jaden Software Tuning 2 02-10-2018 11:45 PM
Managing defs when comparing OFT and non-OFT ROM derek1ee Software Tuning 9 04-22-2016 05:13 AM
Romraider Down? RustySocket Software Tuning 7 10-02-2015 10:28 AM
dbw romraider mod RaineyStar Software Tuning 1 06-05-2015 12:53 PM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 06:29 AM
