| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 | |
Drives: Jeep Wrangler
| The Following User Says Thank You to Coachrhino11 For This Useful Post: | JSube (03-02-2018) |
#30 | |
Junior Pizza Joe
Drives: 2017 BRZ Limited Manual WRB
![]() Besides, if I had them I would probably get used to it and keep it the way I bought it. I'm lazy like that. I mean, really, I'm kinda okay with the stock Michelins. I put on winter Continentals, and I can't wait to get my summer tires back.
Scooby-Doo: Scooby-Dooby-Doo!
Shaggy: And like, Shaggy too. |
| The Following User Says Thank You to Willie Swoopes For This Useful Post: | Grady (03-01-2018) |
#31 | |
Drives: 2014 BRZ Limited
http://www.ft86speedfactory.com/toyo...l#.WpjFC2rwaM8 You can find them even cheaper on Ebay. Understand that you can't just pry the panels out. You have to remove the center console first so they can slide out. That DIY linked somewhere above was excellent, but all the pics are dead. Still, it's worth a read through. You have two options for factory armrests. There's the Toyota JDM one that looks like this: ![]() http://www.ft86speedfactory.com/toyo...l#.WpjHBWrwaM8 There's also the Scion one that looks like this: ![]() https://www.oempartstoyou.com/oem-pa...ter-pt47818130 The flip up armrest looks better, but it pretty much renders your cupholders useless. It's also kind of low for us taller Americans. I would have to lean way over gangsta style to use it. The sliding armrest is slightly less attractive but is considerably more functional. It allows you to slide the pad out of the way to use the cupholders and/or access your storage area and power plug. It's also taller, which was the selling point for me. I can drive comfortably with my elbow right on it. There are some aftermarket armrest options, but IMO none of them look or function as well as the OEM options. |
#32 |
Drives: 2017 ISM PP BRZ
I understand why the ND and the BRZ get compared all the time, but they're pretty different. The Mazda is a very tight cockpit without breathing space behind the seats like the Sube has. Psychologically and functionally it makes a difference. And while the ND is a great handler, the body roll in corners is mental- I like the flat attitude of the BRZ. The seats are better in the BRZ, the Mazda has very creatively designed beach chairs. But if you're a convertible guy, there's no better choice than the ND, and the RF is a cool thing. Also, the ND's engine delivers linear power delivery, I had to spend $$ to bring my BRZ "up to speed."
Raceseng Circuit Sphere 100 shifter arm, Radium catch can and master cylinder brace, Perrin oil cooler, Vorshlag front camber plates, ACE A350 header & overpipe, Berk catted front pipe, CSGxMXP exhaust, Delicious NA Stage II tune & Flex Fuel
#33 | |
Drives: 2017 brz
#34 |
Drives: Legacy
Just test drove a 2017 last Saturday, the knee pad is not any softer to my leg, the problem is my leg bone not the kneecap is resting directly on the console.
I did find this that may be a solution. https://www.ebay.com/i/141933461330?...D1458776857324 |
#35 |
Junior Pizza Joe
The knee padding on the 2017s is much thinner than those aftermarket photos (see above)
Its more of a surface covering surrounding the door speaker, and the footwell about half an inch thick. Am I back on thread?
#36 |
Drives: Legacy
Yes, the new material is leather or leather look but not soft, I’m guessing most people don’t have the same issue which I do.
#37 | |
Milton 86 Club
Drives: Lexus IS350, GT86, Mini Cooper, CBR
I agree some other aftermarket options are softer. Use the links people have posted in the thread for some Alcantara ones as opposed to leather, since it will be a softer feel for you. Sent from my iPhone using Tapatalk |
#38 |
Wasn’t there a children’s story about this?
Princess and the pea or somthing like that? Or was it about 3 bears? |
| The Following User Says Thank You to Grady For This Useful Post: | Tcoat (03-07-2018) |
#39 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Only a REAL princess can pee through 12 mattresses.
"I gotta rock." -- Charley Brown |
#40 |
Drives: BRZ Limited, WRB
had to search all the way back to 2007 for pics, when i did this to my 05STi. But its really easy to do yourself. some spray on adhesive and some foam, and some material to cover the foam with.
| [QUESTION] 2017 Toyota 86 In Canadian snow? | milkydude12 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 10-03-2022 10:05 AM |
| 2017 aftermarket steering wheel horn question | HachiRolle | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 06-20-2022 07:30 AM |
| CSCS Mid Summer DRIFT 2017 - Round 3 - SUN July 23 2017 @ TMP CAYUGA SB LAYOUT | DTrouble | CANADA | 0 | 07-19-2017 09:42 PM |
| 2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? | Extreme Dimensions | Off-Topic Lounge [WARNING: NO POLITICS] | 6 | 06-08-2017 09:59 AM |
| Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift | ModinJapan | Southern California | 1 | 01-25-2017 01:46 AM |
