Old 03-01-2018, 08:49 AM   #1
Rai-zero
Drives: Legacy
Question about new BRZ 2017/18 soft knee pad?
I tested a 2015 BRZ yesterday and was quite pleased for the most part except for my right knee which was in contact with the center knee pad area which is hard plastic. Wanted to ask if the new revised car has improved this with softer material?
I was looking that it’s possible to replace with some aftermarket solution but I’m not sure if I want to buy a new car and start replacing parts like this. I also need to add an armrest.
Later I tested a MX5 which was very fun but just too small for me, I don’t have an inch in any direction. Funny enough my legs were more comfortable with no hard points and I fit in the car, but my head was 1 inch form the roof and it would be impossible to have worn a jacket.
I had owned a S2000 for 6 years but my right thigh developed a numb spot due to resting on the center tunnel, this didn’t happen all at once but over the years so that I began to put a foam pad to keep my thigh from contacting the center tunnel, I maybe could have get different seats but in the end just sold the car.
I don’t want to repeat the same with BRZ if the right knee area is going to be a big issue.
Has anyone found this to be any improvements in the newer car?
Rai-zero is offline   Reply With Quote
Old 03-01-2018, 08:56 AM   #2
Coachrhino11
Drives: Jeep Wrangler
How tall are you? I’m 6’2 and drove and fit in new RF somehow but yeah, need more room! I found place here that will help me select and install bucket seat in Miata to give more room, I wouldn’t do that in new RF but in NC I’m definitely open to that. I’ll be testing BRZ soon.
Coachrhino11 is offline   Reply With Quote
Old 03-01-2018, 09:48 AM   #3
Rai-zero
Drives: Legacy
I’m 6-2 also medium build 203 lbs.
The BRZ had a lot more room inside for driver.
My only issue with the fit was lack of armrest (should be standard) and hard plastic where my right knee falls (actually below the knee the top of the tibia).
As for driving this was a 2015 and I’m not sure if the new car has better tires, but the 2015 was severely under tired meaning it was almost like what you’d feel like in a normal car if you were driving in the rain. I don’t mean once it’s moving but from a start they tires don’t have any grip.
Old 03-01-2018, 10:31 AM   #4
reebis
reebis's Avatar
Drives: 2020 STI Limited
I'm 6'6" @ 240lbs and fit fine in my 2017 BRZ. I have a long torso, so I typically have to recline the seat pretty far back in any car (not uncomfortably though) and still fit with a helmet with about an inch of clearance to the roof. I actually feel like i have more room in the front in this car than my previous 2001 2.5RS.
The 2017s have knee pads stock on the center console and doors. Not sure if the pre-2017 cars have it or not.
reebis is offline   Reply With Quote
The Following User Says Thank You to reebis For This Useful Post:
Tristor (03-01-2018)
Old 03-01-2018, 10:48 AM   #5
yurikaze
yurikaze's Avatar
Drives: 2018 BRZ tS (CBS), AE86 GT-S, MA70
The 2018 I have has soft upholstered padding where your knees touch the door and center stack.
yurikaze is offline   Reply With Quote
Old 03-01-2018, 10:57 AM   #6
Rai-zero
Drives: Legacy
Thanks,
I’m going to text drive one on Saturday in that case.
It sounds like the mid cycle refresh had a lot of good additions.
Old 03-01-2018, 11:29 AM   #7
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Correct, the '17+ cars have the knee padding on both sides, which is a big improvement. You also have the option of the performance package, which gives a much nicer ride quality.
trippinbillies40 is offline   Reply With Quote
The Following 4 Users Say Thank You to trippinbillies40 For This Useful Post:
JSube (03-01-2018), spike021 (03-07-2018), Tcoat (03-01-2018), Tristor (03-01-2018)
Old 03-01-2018, 11:33 AM   #8
Is the first year that the BRZs have the padding? My 14 FRS has it and I thought the BRZ got it sooner. Seems like a basic item for them to take so long to include in the "upscale" cars.
Old 03-01-2018, 12:03 PM   #9
Grady
Grady's Avatar
I would not buy a 17+ without the PP! $1K add on. That package is a no brainer!
The Following 4 Users Say Thank You to Grady For This Useful Post:
JSube (03-01-2018), spike021 (03-07-2018), trippinbillies40 (03-01-2018), Tristor (03-01-2018)
Old 03-01-2018, 12:07 PM   #10
trippinbillies40
Drives: '22 WRB
Honestly not sure. I'd have to look into it. I was an FRS guy till I started working for Subaru
The Following User Says Thank You to trippinbillies40 For This Useful Post:
Tcoat (03-01-2018)
Old 03-01-2018, 12:11 PM   #11
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
i think the brz may have started including them from 2016 on whereas the FRS started getting them earlier. but quite frankly they are very easy to swap out and i doubt they would be that expensive...find a part out thread?
HKz is offline   Reply With Quote
The Following User Says Thank You to HKz For This Useful Post:
Tcoat (03-01-2018)
Old 03-01-2018, 12:44 PM   #12
bkharmony
bkharmony's Avatar
Drives: 2017 86GT
Toyota owner here wishing he had bought a Subaru. I went to check out the BRZ with PP, and couldn't find options for it on the Subaru site or any dealer site - only Sit option. Is the PP a dealer-installed option? What gives?
bkharmony is offline   Reply With Quote
Old 03-01-2018, 12:59 PM   #13
Rai-zero
Drives: Legacy
Is on Subaru website as option $1195 which includes larger Brembo brakes same as on STI (I believe) larger 7.5” wide wheels and firmer dampers.
Has to be factory option, there’s no way a dealer will be replacing brakes and wheels and dampers for $1200.
Old 03-01-2018, 01:19 PM   #14
Rakshaa
Milton 86 Club
Rakshaa's Avatar
Drives: Lexus IS350, GT86, Mini Cooper, CBR
@Rai-zero - all FR-S/86 models came with the kneepads and door pads 2014 and onwards. As for the BRZ, definitely 2017+ in all of NA but I thought the earlier models had it as well. Maybe Canada only?
Rakshaa is offline   Reply With Quote
[QUESTION] 2017 Toyota 86 In Canadian snow? milkydude12 Scion FR-S / Toyota 86 GT86 General Forum 56 10-03-2022 09:05 AM
2017 aftermarket steering wheel horn question HachiRolle Cosmetic Modification (Interior/Exterior/Lighting) 9 06-20-2022 06:30 AM
CSCS Mid Summer DRIFT 2017 - Round 3 - SUN July 23 2017 @ TMP CAYUGA SB LAYOUT DTrouble CANADA 0 07-19-2017 08:42 PM
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 08:59 AM
Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift ModinJapan Southern California 1 01-25-2017 12:46 AM
