| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 | |
Drives: GR Corolla
I have a NoCo Genius battery charger that I throw on every other week just so the battery doesn't go flat. |
#16 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I've had good UOAs with 8-9k intervals from a few years ago. Don't think I have them anymore though.
Using both Mobil1 and Castrol 0w-20 and OEM Tokyo Roki filters |
| The Following User Says Thank You to finch1750 For This Useful Post: | 8RZ (03-06-2018) |
#17 |
Ahhhh.........yes, I often think how simple it was in the old days. I'd change the oil in the spring and put in 30 weight and then change the oil in the fall and put in 20 weight and it didn't matter what brand.
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | chaoskaze (03-23-2018) |
#18 |
Drives: 2013 Firestorm FR-S AT
I use full synthetic in all my vehicles. My Ford Escape makes it easy, since I'm too old to remember and too lazy to write it down, and tells me when to change the oil, which is usually around 9,800 miles.
Not going to debate this, plenty of oil threads here for that, I change the oil on the FR-S once a year, or ~every 10,000 miles. I checked the manual and there is no "Hey DA time to change the oil indicator" on the FR-S. https://www.toyota.com/t3Portal/docu...f/OM1372QG.pdf Last edited by RickyBobby; 03-03-2018 at 10:17 AM. |
#19 |
The Gunshine State
Drives: '14 BRZ Limited
I'm thankful for this, one less dummy light on the dash to worry about lol.
![]() Current DD: M235i |
#20 |
Drives: 2015 BRZ Limited
WOW and here I am beating my self up for only changing my oil once in the last year.. (I only put 4k miles on the car in that time too)
| The Following User Says Thank You to JeremyR For This Useful Post: | Clipdat (03-07-2018) |
#21 |
| The Following User Says Thank You to humfrz For This Useful Post: | JeremyR (03-07-2018) |
#22 |
A.K.A. Starlord
Drives: 2015 Series.Blue
I've been doing 10,000 mile intervals since I bought the car (apart from the first oil change done at 6,000 miles when I switched it out for AMSOIL) and I've been doing Blackstone Labs analyses with every oil change as well. It's not uncommon for me to run an entire season of autocross on the same oil change (that means at least 10 events, towing a trailer to/from events, and this is also my daily driver here in Chicago, so a lot of "city use" which is harder on oil, not to mention use throughout winter as well.
No issues thus far
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | Teseo (03-08-2018) |
#23 | |
Drives: 10 Series #974 6m/t
#25 |
Drives: BRZ SWP Limited -6MT
#26 |
#27 | |
Drives: 2017 manual BRZ
Sent from my Pixel XL using Tapatalk |
#28 |
ZWEI KOLBEN
Drives: 2017 86 Halo 6MT
I changed to Mobile One at 250 miles, just to clean up the possible manufacturing junk in there. I changed again at 5K miles and will probably change next month when I hit 10K. I need to swap out the gearbox oil with some Redline.
Love Motul 300V in all the motorcycles, but no source for auto version around here. |
| how many miles before first oil change | Anthony7515 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 72 | 10-25-2014 10:35 AM |
| Just purchased my '13 BRZ with 1,800 miles. Should I change the oil? | torqueno | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 10-08-2014 10:55 PM |
| Oil change at 4100 miles | djdrugga24 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 03-28-2014 02:00 PM |
| Almost at 1000 miles. Oil change when? | TheGuyWithTheFireStorm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 08-08-2013 12:31 PM |
| Oil change at 1000 miles. | Dorb | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 03-08-2013 04:18 PM |
