Old 03-03-2018, 01:18 AM   #1
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
bad window seal at high speed?
So for some reason it sounds like my window is slightly cracked(letting air in) when i'm hitting high speeds (100+ mph), when i slow down, the wind noise go away. its been a problem for a while now, has anyone else experienced this? Maybe a bad seal?
slyphen is offline   Reply With Quote
Old 03-03-2018, 01:47 AM   #2
.......and what track are you going a 100 mph on .......
Maybe plug up the sound maker tube ....... it may be over pressurizing the cabin .....
And here all along, I thought that sound I was hearing outside was jets landing at Seatac .......
Old 03-03-2018, 06:06 AM   #3
kimcheefists
kimcheefists's Avatar
Drives: 2017 BRZ PP
I had that problem in my 15 BRZ too. I just dealt with it. I can’t really say that I have the same problem with my 17 though..
kimcheefists is offline   Reply With Quote
Old 03-03-2018, 01:46 PM   #4
ls1ac
ls1ac's Avatar
The doors seem to be pulled out and leak around the seals. I just thought it was an aero thing at speed. On track windows are usually down.
Old 03-03-2018, 04:02 PM   #5
Welcome to the world of frame-less windows. The faster you go the greater the pressure difference between the inside and out side of the car. Since there is no frame to hold it the differential will pull the glass out a bit. It only takes a very, very small gap to make a pile of noise. There is no fix since there is nothing wrong. This is not unique to this car and has happened with every coupe I have ever owned. The only answer is to slow down.
Dadhawk (03-04-2018)
Old 03-04-2018, 03:38 AM   #6
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Going slower is never the answer! Never!
carsebuco is offline   Reply With Quote
The Following 3 Users Say Thank You to carsebuco For This Useful Post:
Somerandom18 (03-04-2018), Tcoat (03-04-2018), Tristor (03-04-2018)
Old 03-04-2018, 01:16 PM   #7
daskaman
Drives: Burz
Lube up your weatherstrippings. Hydrated seals help the tiniest bit to keeping seals happy.
I have used Sil-Glyde and Gummi Pflege
daskaman is offline   Reply With Quote
Old 03-04-2018, 03:37 PM   #8
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
Check that the weatherstripping isn't rolling over when the window rolls up. Mine does this.
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 03-04-2018, 05:19 PM   #9
Tristor
Tristor's Avatar
FWIW I have this problem too. Sometimes it helps to roll the windows down slightly and then roll them all the way up. It seems like the windows slip down slightly due to pressure differential at high speed.
Tristor is offline   Reply With Quote
Old 03-04-2018, 08:57 PM   #10
BRZnut
Drives: BRZ DGM Limited
only at 100 mph? Mine sometimes makes noise at 45 MPH. Consider yourself lucky!
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Drivers window grabbing window seal and pushing it up. stockysnail Issues | Warranty | Recalls / TSB 22 12-22-2015 02:08 PM
Window seal cracking ironsurfer129 Scion FR-S / Toyota 86 GT86 General Forum 9 11-29-2014 09:59 PM
window seal deforming mokinbird87 Issues | Warranty | Recalls / TSB 33 10-31-2014 06:14 PM
window seal? ravenblackfrs Issues | Warranty | Recalls / TSB 3 01-29-2014 06:12 PM
