Old 03-04-2018, 12:15 PM   #1
Dee
Drives: 2014 Asphalt FRS
Alignment question
So I installed some ST coilovers. Pretty happy, besides some clunking in the rear.
I also installed adjustable SPC lower control arms (rear).
So to make this short, the front alignment was exactly what I wanted. 1.8 camber 0 toe.
However in the rear, the technician said he could get 1.3 camber on the left rear(exactly what I wanted), but on the right rear he could only get down to 2.1 camber. So I had to settle and get 2.1 camber on both sides of the rear
I am not very knowledgable of alignments, I have a little bit of suspension knowledge, but.. why was he able to only get 2.1 on one side while the other he could get 1.3? Is it possible he didn’t know how to adjust the control arm?
P.S. all of the numbers provided are negative camber
Dee is offline   Reply With Quote
Old 03-04-2018, 12:30 PM   #2
I really doubt he didn't know how to adjust the LCA.
The bigger question here is what is causing the "clunk"?
There should not be "clunking".
Old 03-04-2018, 12:32 PM   #3
Lust
Drives: 2017 Subaru BRZ
Double check to make sure everything is installed correctly. The clunk is worrisome.
Lust is offline   Reply With Quote
Old 03-04-2018, 01:06 PM   #4
Dee
Disconnected endlinks, was still happening. My friend in automotive school thinks it’s the bushings. I personally think it’s something with the top hats cause the sound appears to be coming from there. It’s died down a lot since install. Just really over big bumps.
Old 03-04-2018, 01:20 PM   #5
Did you tell the tech you have this clunk?
Old 03-04-2018, 01:34 PM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
Something seems off. I'm not sure I can get toe right at only -1.3° camber in the back. Plus that clunk.
Old 03-04-2018, 01:52 PM   #7
Dee
I think he was able to get very little toe, like 2%, in the rear with -1.3* camber. So, why was he not able to get 1.3 on the right side?
I believe the clunk is just the top hat hitting the trunk. I’m not very concerned with it since it’s only over large bumps. I may get a tech to check it out.
Old 03-04-2018, 02:00 PM   #8
cjd
cjd's Avatar
Drives: 2017 BRZ
You should be able to get zero toe and -3°... Assuming the car is lower on the coils. Stock should fall around -2° or more, lowered.
Also, clunks lead to broken parts. Just because you only hear it over big bumps, the constant chatter is there. Fasteners aren't rated for that and eventually break.
Old 03-04-2018, 02:58 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Look at the camber adjuster on the LCA's and see where they are at. If you are not sure what you are looking at post a pic of each side. I can't imagine what would be off that you can't get the adjustment you need.
Old 03-04-2018, 06:22 PM   #10
Dee
This is the camber adjustment right? If so left and right arms are shown. I can provide better pictures if those aren’t clear enough
Old 03-04-2018, 06:52 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Those are good pics.
Yeah both those are only about half way through their adjustment range so I don't know why he can't get the same on both sides unless he couldn't get the one adjuster to spin. So he just used that as an excuse.
Old 03-04-2018, 09:11 PM   #12
Dee
Ah, thank you. When I go back, I will show him the picture. How exactly do you adjust these, in case he asks?
Old 03-04-2018, 09:52 PM   #13
Brink
Drives: 2017 BRZ
If an alignment tech asked me how to adjust any alignment characteristics on my car I'd find another shop.
Brink is offline   Reply With Quote
The Following 2 Users Say Thank You to Brink For This Useful Post:
justint5387 (03-05-2018), Tristor (03-05-2018)
Old 03-04-2018, 10:54 PM   #14
I'd just find a different shop and tell them what the first guy said.
Make sure you ask for printouts of both before, and after.
finch1750 (03-05-2018)
Alignment question. ohnoitsthefuzz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-09-2015 08:33 AM
Alignment Question Covo_86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 06-04-2014 12:37 PM
brz alignment question Shenks BRZ First-Gen (2012+) — General Topics 2 02-12-2014 10:23 PM
alignment question hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-15-2013 01:52 PM
Alignment question retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-11-2013 11:44 PM
