#85 |
Drives: 2013 scion frs firestorm red
Can anyone tell me where to find this line on a left hand drive car? The picture shows it under the brake booster but I cant find it or anything that looks similar to it. thanks
#86 | |
BAE
Drives: Asphalt FRS
Are you talking about the L shape line? Or which line? Should be sound generator tube Last edited by Decimus; 10-12-2017 at 01:51 PM. |
#87 |
BAE
Drives: Asphalt FRS
Did everyone change out their MAP sensor after installing this kit? 3 bar?
#88 |
#89 |
BAE
Drives: Asphalt FRS
So aftermarket MAP sensor is not needed for this t518z application unless we're trying to go over 14.7psi of boost? If we want a tune for hi&low boost, is that when we need an aftermarket MAP? Stock MAP is a 2bar (or some say 1.6bar)?
#90 | |
It depends on how your setup is tuned. |
#91 |
Drives: 2017 Subaru BRZ
I've been considering getting this kit recently. Anyone able to chime in on how it compares to other top turbo/SC solutions available like JDL, Full Race, Edelbrock, JR, etc?
#92 | |
Drives: Toyota GT86
If you want room for more power later get the T620z for about +400whp with E85. If you want an all around kit and the potential to go all the way to 500hp later, this is not a kit for you. I'd go with JDL and a GTX3076R. Sent from my Pixel XL using Tapatalk |
| The Following User Says Thank You to BRX For This Useful Post: | Lust (11-15-2017) |
#93 | |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Exactly what BRX said. I ran the T620z on 10lbs of boost for a good 18k miles on a stock engine with no issues (293 WHP automatic trans). I decided to turn up the boost to 18lbs since I'm on a built block now.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
#94 |
How’s the response on it? Do you know how it would compare to the 518?
#95 |
JDM Spirit of the '90s
Drives: 2015 FR-S Turbo
For those of you who paid to get this kit installed, how much was it? I was quoted $2500. Does it make sense to you? Thanks!
#96 |
Drives: Toyota GT86
| The Following User Says Thank You to BRX For This Useful Post: | Raven86Project (03-04-2018) |
#97 |
I was quoted 1k but I had a few other things other than just the T518z kit.
| The Following User Says Thank You to Lust For This Useful Post: | Raven86Project (03-04-2018) |
#98 |
Drives: 2017 BRZ Limited
How do you guys like this kit when considering the heat it brings? I want to buy this ASAP, but I will have big time buyers remorse if it cant support my commutes. I drive on the German Autobahn (avg 95-120 mph for 2 hours at a time/ 4 times a month). I already had oil temp problems on a stock engine in the winter. So I just purchased the JR dual radiator/oil cooler. Do you guys think I will have heat problems with this kit?
| Greddy / Trust Turbo Kit (Video and Pictures) | BPAuto | Forced Induction | 62 | 03-18-2016 06:04 AM |
| BRZ GReddy t518z | NOTORIOUS.BRZ | BRZ Photos, Videos, Wallpapers, Gallery Forum | 26 | 04-15-2014 02:15 PM |
| GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) | NOTORIOUS.BRZ | Engine, Exhaust, Transmission | 21 | 09-24-2013 06:09 PM |
| GReddy Tuner T518Z Turbo Kit Fitted / Photos/ DYNO/ Video ! | NOTORIOUS.BRZ | Forced Induction | 17 | 07-29-2013 04:42 PM |
