Old 03-01-2018, 02:23 PM   #15
Originally Posted by bkharmony View Post
Toyota owner here wishing he had bought a Subaru. I went to check out the BRZ with PP, and couldn't find options for it on the Subaru site or any dealer site - only Sit option. Is the PP a dealer-installed option? What gives?
It is only an option for the Limited. It shows up in the features and build section of the site.
https://www.subaru.com/vehicles/brz/features.html
bkharmony (03-01-2018)
Old 03-01-2018, 02:40 PM   #16
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
Originally Posted by Rai-zero View Post
I tested a 2015 BRZ yesterday and was quite pleased for the most part except for my right knee which was in contact with the center knee pad area which is hard plastic. Wanted to ask if the new revised car has improved this with softer material?
I was looking that it’s possible to replace with some aftermarket solution but I’m not sure if I want to buy a new car and start replacing parts like this. I also need to add an armrest.
Later I tested a MX5 which was very fun but just too small for me, I don’t have an inch in any direction. Funny enough my legs were more comfortable with no hard points and I fit in the car, but my head was 1 inch form the roof and it would be impossible to have worn a jacket.
I had owned a S2000 for 6 years but my right thigh developed a numb spot due to resting on the center tunnel, this didn’t happen all at once but over the years so that I began to put a foam pad to keep my thigh from contacting the center tunnel, I maybe could have get different seats but in the end just sold the car.
I don’t want to repeat the same with BRZ if the right knee area is going to be a big issue.
Has anyone found this to be any improvements in the newer car?
Knee pads
http://www.ft86speedfactory.com/cata...=0&q=knee+pads
Console arm rest
http://www.ft86speedfactory.com/cata...est&q=arm+rest
And trippinbillies is right, the Sachs dampers in the 17+ PP cars provide a really good ride, plus you get proper brakes (for track anyway) and pretty wheels for $1K.
Raceseng Circuit Sphere 100 shifter arm, Radium catch can and master cylinder brace, Perrin oil cooler, Vorshlag front camber plates, ACE A350 header & overpipe, Berk catted front pipe, CSGxMXP exhaust, Delicious NA Stage II tune & Flex Fuel
JSube is offline   Reply With Quote
The Following User Says Thank You to JSube For This Useful Post:
spike021 (03-01-2018)
Old 03-01-2018, 02:55 PM   #17
Originally Posted by Rakshaa View Post
@Rai-zero - all FR-S/86 models came with the kneepads and door pads 2014 and onwards. As for the BRZ, definitely 2017+ in all of NA but I thought the earlier models had it as well. Maybe Canada only?
That is possible. I was pretty sure they had them here in 16.
Old 03-01-2018, 03:08 PM   #18
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Welcome to 2012.
http://www.ft86club.com/forums/showthread.php?t=13583
krayzie is offline   Reply With Quote
Old 03-01-2018, 03:42 PM   #19
Rakshaa
Milton 86 Club
Rakshaa's Avatar
Drives: Lexus IS350, GT86, Mini Cooper, CBR
Yup I thought so too
Rakshaa is offline   Reply With Quote
Old 03-01-2018, 04:38 PM   #20
bkharmony
bkharmony's Avatar
Drives: 2017 86GT
Thanks, I see it now. Makes me ill... I got the 2017 86 with nav because I thought it included a better entertainment system. It doesn't. The nav is useless, and for the same price I could've gotten the BRZ with PP. Adding the same Brembos to my car will probably run about $2500 now.
It was frustrating as #$&% buying this car. Not one salesperson in four dealerships knew anything about it. One Subaru guy couldn't even tell me the difference between the Limited and Premium.
Me: "So what's the difference between the Premium and Limited?"
Salesguy: "I'm not sure."
Me: "Well, do you have any brochures?"
Salesguy: "No, we're all out."
Me: walking out...
Salesguy: Following me, "So you wanna order one?"
I just hit my 1st anniversary. I'm seriously considering trading in the 86 for a Limited PP. I'd probably lose a ton on money.
bkharmony is offline   Reply With Quote
Old 03-01-2018, 04:52 PM   #21
Me: walking out...
You would lose a ton of money. The PP is a spectacular deal if you track the car. Sort of overkill (other than the sweet appearance) if you do not.
Old 03-01-2018, 06:11 PM   #22
Willie Swoopes
Junior Pizza Joe
Willie Swoopes's Avatar
Drives: 2017 BRZ Limited Manual WRB
I ordered my 2017 without the PP.
All the cars I found on lots had it already so if I wanted one without I had to order it.
I was looking for a run-about, not a track car. I saved 1k which I spent on winter tires and used Scion rims.
Did a lot of internet research before the purchase. When I went into the dealers I already knew what I wanted and what I was getting before ordering the car. I was answering the dealers questions in many cases.
A&T Subaru in Sellersville PA was great; no gouging, ordering and communicating well. Ordered the car and waited (the hardest part).
Then
Scooby-Doo: Scooby-Dooby-Doo!
Shaggy: And like, Shaggy too.
Willie Swoopes is offline   Reply With Quote
The Following 3 Users Say Thank You to Willie Swoopes For This Useful Post:
Geese1 (03-01-2018), Spuds (03-01-2018), Tcoat (03-01-2018)
Old 03-01-2018, 06:17 PM   #23
arkanist
Drives: 2016 BRZ Limited, Stock
Originally Posted by reebis View Post
I'm 6'6" @ 240lbs and fit fine in my 2017 BRZ. I have a long torso, so I typically have to recline the seat pretty far back in any car (not uncomfortably though) and still fit with a helmet with about an inch of clearance to the roof. I actually feel like i have more room in the front in this car than my previous 2001 2.5RS.
The 2017s have knee pads stock on the center console and doors. Not sure if the pre-2017 cars have it or not.
Can I get a picture of you in there with a helmet? I have all but given up on clearing a helmet without a lot of work. I am only 6'3" and my head is pretty much on the headliner.
arkanist is offline   Reply With Quote
Old 03-01-2018, 07:18 PM   #24
Geese1
Geese1's Avatar
Drives: 2018 BRZ w/ PP - WRB
Then
I just ordered mine this week with the PP, but yeah, I knew exactly what I wanted when I headed into the dealership and had everything printed out as far as the cost of what I wanted, as well as what my trade should be worth. Was talking to my salesman and he said that they hadn't had a new BRZ on the lot since they were first introduced back in 2013, which is why it took an extra day for them to actually put the order in - they weren't sure what code to use to get the PP and had to check with their Subaru rep to make sure they got everything right!
Late April / early May delivery (hopefully sooner), so yeah, now comes the waiting.
Geese1 is offline   Reply With Quote
Old 03-01-2018, 07:22 PM   #25
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
My 2015 Series.Blue BRZ came with the soft knee pads
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 03-01-2018, 07:33 PM   #26
Coachrhino11
Drives: Jeep Wrangler
Agree about losing a bundle but if buying new an extra grand is nothing for what you get compared to Mazda charging over 3k for bbs/brembo package. Both look great!
Coachrhino11 is offline   Reply With Quote
Old 03-01-2018, 07:44 PM   #27
Yes but losing $5,000 to save $1,000 doesn't make a whole lot of sense. Be better off to get an idea of what would be lost in a trade in against what it would cost to do the same thing through the aftermarket.
Old 03-01-2018, 07:51 PM   #28
Grady
Grady's Avatar
Then
You could have bought the one with the PP. found someone to give you stock breaks and struts. Sold the PP brakes, wheels and struts for $2K pocketed $1K
[QUESTION] 2017 Toyota 86 In Canadian snow? milkydude12 Scion FR-S / Toyota 86 GT86 General Forum 56 10-03-2022 10:05 AM
2017 aftermarket steering wheel horn question HachiRolle Cosmetic Modification (Interior/Exterior/Lighting) 9 06-20-2022 07:30 AM
CSCS Mid Summer DRIFT 2017 - Round 3 - SUN July 23 2017 @ TMP CAYUGA SB LAYOUT DTrouble CANADA 0 07-19-2017 09:42 PM
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 09:59 AM
Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift ModinJapan Southern California 1 01-25-2017 01:46 AM
