| Software Tuning Discuss all software tuning topics. |
Huge E85 fan!
Drives: 2016 Scion FRS
Dyno day results- gutted + E85
Dynojet
-Injen v1 intake -gutted header and FP -Works axleback & cherry bomb -OFT OTS Stg 2 E85 tune It's running a bit lean. The E85 I got in the last tank is less than 85% ethanol judging from my AFR (I have a gauge) and fuel trims. No FFK. Not enough to be an issue though. Numbers looked good, we have pretty good E85 around here. They had some trouble getting an RPM signal and my car sat idling for about 10 mins and my IAT was up over 120, I couldn't even feel their fan! That didn't help my numbers. If my IAT was lower, I'd have been over 200 HP... but I was not. No whining I'm happy with the results. The total price of this set up (the relevant bits anyway) is about $650 altogether. I got the intake, Works axleback and OFT used locally. I could have done this for under $400 and had similar numbers. Plus running E85 is a cost SAVING over 93 (I did the numbers) and (though I haven't done the numbers) I think would be a saving over 91 even. Plus it smells so delicious. A better header would get me better numbers, but a better HP/$ and Tq/$ - I don't think so. Not sure. Ecutec or custom tune would net better numbers too. Also the stock header means stock heat shields so heat isn't an issue under the hood. There's trade-offs for sure. It's a challenge to pursue extra power but keep it cheap. Nice flat Tq curve- most of what I have done has been in the pursuit of more Tq. The smaller runners on the stock header don't do much for peak HP, but look at the tq curve. Up around 159 lb-ft peak looks great to me. Torque dip? Gone. Plus you can't get much cheaper. Almost 200 HP....so close! I'll take 197 peak WHP. That weird dip is where I was shifting. Interestingly, I was making power right up to the rev limiter. |
| The Following 6 Users Say Thank You to guybo For This Useful Post: | Code Monkey (02-24-2018), DAEMANO (03-02-2018), Hades (02-26-2018), new2subaru (02-24-2018), Tectoniic (02-24-2018), Teseo (02-25-2018) |
#2 |
Drives: 2013 frs red
Nice numbers. Congrats!
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | guybo (02-25-2018) |
#3 |
Huge E85 fan!
I made a video, not much to see. But I am an Ethanolholic now! I'm a full convert despite my misgivings at first
#4 |
Drives: Frs
check the tune, pretty sure it s pulling timing based on IAT by 119 degreesF or so. whered you run it?
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
#5 |
How do I shift?
Drives: '13 GBS BRZ
I haven't run a dyno on mine since I don't have that much money to just throw around, but running Stage 2 UEL + E85 is indeed pretty awesome... I'll miss it when I move 8 miles south and it is no longer a viable drive to get some corn juice
#6 | |
Huge E85 fan!
Ah well, $50 for 3 pulls isn't bad. |
#7 |
Drives: 2013 frs
I have a friend with tomei el header, fa20club intake and oft e85 tune made 202 so yup hp/$ you good lol
| The Following User Says Thank You to sid94 For This Useful Post: | guybo (03-05-2018) |
| Gutted Header & Front Pipe - Dyno Inside | Joe-G | Engine, Exhaust, Transmission | 60 | 04-15-2020 02:34 PM |
| My Nameless header dyno results (results to follow) | Simply_the_best | Engine, Exhaust, Transmission | 39 | 06-28-2016 05:09 PM |
| Australian Dyno Dyno Results | Shiv@Openflash | Software Tuning | 11 | 07-22-2015 05:57 AM |
| 86 Dyno results | Anban | AFRICA | 18 | 01-14-2014 07:54 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 08:00 PM |
