#29 |
Drives: '13 FRS - STX
Maybe for mk2 in 2024
#30 | |
#31 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
Gotta admit, I do listen to the music system in my car (not the actual radio, but music via the usb input).
I listen to music more often than I did upon first ownership. Would I miss the 'radio' if it were not there ? Probably rarely. Also it's much safer at my age driving sans distractions. I always turn off music in heavy traffic. Getting old... |
#32 |
Drives: 2013 FR-S MT Hot Lava
Let's be perfectly honest here. Does anyone really think this car will be around long enough to even warrant an overhaul of the interior? Two,maybe three years max is about as long as I see this car being around.
#33 | |
....... the Miata has hung around for several years .....![]() humfrz |
#34 | ||
Drives: 2014 BRZ Limited
Or you could just complain about not having an armrest, when a perfectly adequate solution exists. |
#35 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
The Australian 86 has had a start button since 2012.
I like the steering wheel having no buttons. |
#37 | |
![]() And damn those angled controls would have made pulling the choke knob a lot easier than being inset and behind the steering wheel. I have no idea how anybody managed to drive before everything was an inch away. I get the advantages of ergo set ups but for a bunch of guys that want a "raw" car there is a whole lot of nit picking. Carbon inserts instead of plastic? Shift lights in the steering wheel? MORE controls on the steering wheel? When the 86 hits the price point of the Pista then maybe it will have the same features.
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (02-24-2018) |
#38 | |
![]() humfrz |
#39 | |
#40 | |
![]() (spoilt city kid) Before that, once you did find the choke knob and pulled it out, one had to reach all the way over to the center of the floorboard, with your right leg and push the starter pedal. Don't forget to push the choke all the way in after a spell ..... NO, the manual never said how far and for how long to keep it pulled out. If you wanted to dim your headlights ...... you had to find the dimmer switch on the floorboard ..... with your left foot ...... yep, the same one you used to push in the clutch ...... so get your timing right. Fresh air ....... oh yes, just reach under the center of the dash and push the vent lever down. Don't forget to open up the side vent (manually) to let the smoke out. OK, here we go down the highway. Cruise control ..... of course ..... just pull out the throttle cable, that's on the dash, and hold it out with a coin jammed behind it ...... size of coin would depend on how fast you wanted to go. I just don't know how we managed ...... ![]() ![]() humfrz Last edited by humfrz; 02-24-2018 at 03:50 AM. |
#41 |
Drives: 17 86
#42 | |
![]() humfrz Last edited by humfrz; 02-24-2018 at 04:13 AM. |
| Additional ideas and upgrades(My interior so far) | DESTINY-BRZ | BRZ First-Gen (2012+) — General Topics | 22 | 03-07-2015 07:53 PM |
| Custom interior/Soft touch ideas or compilation? | zohare | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 02-15-2013 12:56 AM |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| Your ideas for future sports car market | RaceR | Other Vehicles & General Automotive Discussions | 63 | 10-09-2012 03:34 PM |
| Interior Upgrades - my ideas | Turbowned | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 07-11-2012 02:20 AM |
