#2465 | |
Drives: 2015 BRZ Series Blue WRB
#2466 |
Drives: 2016 Subaru Series.HyperBlue #631
As crazy as people may think this sounds. I actually second this. While I have no problem getting the Flexible V Bars and Flexible Draw Stiffener from Japan I would really like to find the USDM STi V Bars for my build. Black accentuates my HyperBlue and the V Bars maintain that black look
#2467 |
For the front stripe, just a heads up that if you have the older bumper, you'll see small notches on the backside of it when installed. This is because the grille on the newer bumper sticks out further than the older one, which requires the notches to be there.
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread |
| The Following 3 Users Say Thank You to DSOmegaX For This Useful Post: |
#2468 |
Drives: 2015 BRZ Limited
Good to know! I've got a '15 and plan on doing this so thanks for the info.
#2469 | |
Glorious BRZ Master Race
Drives: Subaru Libird
Here are the notches @DSOmegaX was referring to with grille slats protruding from grille frame: ![]() Versus zenki grille slats being flush with the grille frame not needing notches: ![]() The notches seem small enough to not bother me from standing distance. If I'm lucky they'll line up with the zenki slats and, despite not actually touching, won't look too out of place.
| The Following 3 Users Say Thank You to switchlanez For This Useful Post: |
#2470 |
![]() Can always do it with the EU chrome stripe repainted if it does bother you in the end regardless!
@dsomegax.cars
| The Following 2 Users Say Thank You to DSOmegaX For This Useful Post: | jello4018 (02-18-2018), switchlanez (02-18-2018) |
#2471 |
I checked with a friend that i have at the subaru dealer near me and the price for the TS stripes are as follow:
Stripe Rear Bumper - Part #J1210CA401 – 175 + tax Bumper Molding - Part #J1210CA301 – 288 + tax Still expensive for two red stripes TBH. |
#2472 |
Drives: 2017 CWP BRZ w/ PP
Just a quick note! I placed an order for the tS Red Trim (Front and Back) and tS/STI 18x7.5 wheels successfully (at least for now)! So I'll be able to confirm to those wanting these parts. Here are the part numbers for reference. Pics to come!
28111CA130 - 18" tS/STI Wheels J1210CA301 - Front Red/Cherry Stripe tS Molding J1210CA401 - Rear Red/Cherry Stripe tS Molding
My 2017 JDM tS Build
IG: @TheJonRZ |
#2473 |
anyone has the part number for the Brembo BBK comes with the TS or PP?
#2474 |
Drives: '22 WRB
There are several parts numbers as it's not sold as a kit and the whole thing will set you back over $4k all in. You're better off buying aftermarket IMO. But, if you really want the part numbers, let me know and I'll look them up for you when I get a chance.
#2475 |
$4k is still cheaper than getting front and rear Brembo or Stoptech BBK right?
#2476 | |
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
#2477 |
Drives: '22 WRB
Ok let's do this...
Front Caliper Mounting Bracket: 26261FE000, $53.25 x2 Front Mounting Bolt: 901120131, $4.32 x 4 Front Left Caliper: 26292CA060, $699.95 Front Right Caliper: 26292CA070, $699.95 Front Pads: 26296FE100, $299.95 Front Rotors: 26300FE001, $433.77 x2 Front Rotor Shield Right: 26290CA020, $22.27 Front Rotor Shield Left: 26290CA030, $22.27 Rotor Shield Bolts: 901000162, $1.08 x6 Front total: $2742.19 Rear Caliper Right: 26692CA060, $649.95 Rear Caliper Left: 26692CA070, $649.95 Rear Pads: 26696FG000, $239.95 Rear Mounting Bolts: 901000326, $3.37 x4 Rear Total: 1553.33 Front and rear total:$4295.52 It appears that hoses and rear brackets and rotors are the same. This is all MSRP, so you could probably get it all a bit cheaper by shopping around. Keep in mind you'll need wheels that clear the calipers, as well as a couple quarts of brake fluid. |
| The Following User Says Thank You to trippinbillies40 For This Useful Post: | Veloist (02-21-2018) |
#2478 |
Drives: 2017 Subaru BRZ WRB PP
Does anyone have part numbers for the mesh grills on the tS?
| Tags |
| it sucks to be broke, sti omg! |
| WTB: Parts for my FR-S | hyperpunx | Interior Parts (Incl. Lighting) | 1 | 03-05-2013 06:28 PM |
| [Group Deals] SoCal Subaru BRZ parts or Any Parts | Giccin | Southern California | 25 | 08-26-2012 11:30 AM |
