#2661 | |
Drives: 2014 Porsche Cayman S
Sent from my Moto G (5) Plus using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
#2662 |
Unless you're keeping the RPMs low, I would consider an oil cooler to be a mandatory mod for the health of your engine.
#2663 | |
![]() Sent from my Moto G (5) Plus using Tapatalk
#2664 | |
If you're sustaining high RPM for more than a few minutes at a time (e.g. being on track for a 20 minute session), then an oil cooler is vital to proper lubrication, whether you're boosted or not. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Teseo (02-21-2018) |
#2665 | |
![]() ![]() Sent from my Moto G (5) Plus using Tapatalk
#2666 | |
For someone with zero to minimal experience, who won't be sustaining high revs on track, it's totally fine. Anything more than that will mandate an oil cooler. |
#2667 |
Drives: Q5 + BRZ + M796
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Hades (02-14-2018) |
#2668 |
LagunaSeca86
Drives: No stone left unturned
Big power on track
Seems to be a lot of people daily driving this kit, anyone routinely driving it hard on track with a built motor and one of the smaller pulleys?
#2669 |
Several, although they don't regularly post on the forums. Cool the car according to the output level, and you'll be just fine.
#2670 |
Drives: 2017 BRZ Premium
Are the 2017 kits released yet?
Sent from my SM-N950U using Tapatalk |
#2671 |
#2672 |
Drives: Toyota 86 2017 TRD Modded
Hey Mike, I'm assuming you and your crew have tweaked around with this kit long enough to know the ins and outs of what to do and what not to do.
I've decided to go with a 2.5" full exhaust system where the header is EL catless, aftermarket OP, and non-resonated with HFC FP. Next I'm looking to get the Jackson Racing DR/OC + The Edelbrock D Box. I don't have any affordable access to e85 so FF is out of the question. I have looked at Water/Methanol injection which my local area has access to, but unfortunately I'm not certain about it's capabilities and longevity on our cars; especially a 2017 model. One of last thing I've considered so far is to change out the boost pulley from the stock 3.25" (10psi) to the 3" pulley. (12psi) (Correct me if I'm wrong) I am planning to keep the stock motor nor do I plan on building it as my goal for this car is DD and the weekend warrior where I do at the most 5 or 6 drag races. I am aiming for at the most 350whp and ~250wtq I figure the 2.5" EL full exhaust setup + JR DR/OC + Edelbrock D Box will get me close if not over 300whp on 92 octane, but will getting a higher boost pulley with this setup on a 2017 AT 86 be a really bad idea on the stock CR? Sent from my SM-G950U using Tapatalk
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
#2673 | |
350whp will only be possible with race gas, if ethanol isn't available to you. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | ThatAsianBradah (02-21-2018) |
#2674 | |
I've checked out the Edelbrock website and Summit Racing website but no solid on the 3.00 pulley that's the specific fit for the frs/brz/86 model Sent from my SM-G950U using Tapatalk
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
