Old 02-15-2018, 03:29 PM   #2465
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Originally Posted by switchlanez View Post
The 1st set of links I posted (shipping from WA) that you clicked cost slightly more to ship to me than the 2nd set of links I posted (shipping from TX):
https://www.subaruwarehousedirect.co...ing-j1210ca301
https://www.subaruwarehousedirect.co...per-j1210ca401
That still may be expensive for you to ship from TX to NY. I'd look for parts websites based near your area. The parts may cost a little more than the two sites I posted (and definitely cheaper than dealerships) but shipping should be a lot less.
Thanks , is this the same strip you have in your brz? i saw the pics in your build thread and looks great.
Jfheisenberg is offline   Reply With Quote
Old 02-15-2018, 03:39 PM   #2466
Jordan Silveira
Jordan Silveira's Avatar
Drives: 2016 Subaru Series.HyperBlue #631
Originally Posted by norcalpb View Post
Because shipping is $50 for each item and it’ll take like 2 weeks to get. If there’s a USDM version I bet I could save some money. And the new versions are black with a black sti logo. I want as few visible sti logos on my car as possible.
As crazy as people may think this sounds. I actually second this. While I have no problem getting the Flexible V Bars and Flexible Draw Stiffener from Japan I would really like to find the USDM STi V Bars for my build. Black accentuates my HyperBlue and the V Bars maintain that black look
Jordan Silveira is offline   Reply With Quote
Old 02-15-2018, 04:07 PM   #2467
DSOmegaX
DSOmegaX's Avatar
For the front stripe, just a heads up that if you have the older bumper, you'll see small notches on the backside of it when installed. This is because the grille on the newer bumper sticks out further than the older one, which requires the notches to be there.
@dsomegax.cars
The Following 3 Users Say Thank You to DSOmegaX For This Useful Post:
JeremyR (02-16-2018), Jfheisenberg (02-16-2018), Jordan Silveira (02-15-2018)
Old 02-16-2018, 01:09 PM   #2468
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
Good to know! I've got a '15 and plan on doing this so thanks for the info.
JeremyR is offline   Reply With Quote
Old 02-17-2018, 04:48 AM   #2469
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Thanks, I actually used 3M red reflective tape but removed it because it didn't match an STI cherry blossom red skirt I added under the front lip. I don't expect these tS strips to color match exactly because they're different materials but should be close.
Here are the notches @DSOmegaX was referring to with grille slats protruding from grille frame:
Versus zenki grille slats being flush with the grille frame not needing notches:
The notches seem small enough to not bother me from standing distance. If I'm lucky they'll line up with the zenki slats and, despite not actually touching, won't look too out of place.
The Following 3 Users Say Thank You to switchlanez For This Useful Post:
jello4018 (02-18-2018), Jfheisenberg (02-17-2018), SkyeHack (02-17-2018)
Old 02-18-2018, 05:19 AM   #2470
DSOmegaX
DSOmegaX's Avatar
Can always do it with the EU chrome stripe repainted if it does bother you in the end regardless!
@dsomegax.cars
The Following 2 Users Say Thank You to DSOmegaX For This Useful Post:
jello4018 (02-18-2018), switchlanez (02-18-2018)
Old 02-20-2018, 04:55 PM   #2471
Jfheisenberg
I checked with a friend that i have at the subaru dealer near me and the price for the TS stripes are as follow:
Stripe Rear Bumper - Part #J1210CA401 – 175 + tax
Bumper Molding - Part #J1210CA301 – 288 + tax
Still expensive for two red stripes TBH.
Old 02-20-2018, 05:02 PM   #2472
JonRZ
JonRZ's Avatar
Drives: 2017 CWP BRZ w/ PP
Just a quick note! I placed an order for the tS Red Trim (Front and Back) and tS/STI 18x7.5 wheels successfully (at least for now)! So I'll be able to confirm to those wanting these parts. Here are the part numbers for reference. Pics to come!
28111CA130 - 18" tS/STI Wheels
J1210CA301 - Front Red/Cherry Stripe tS Molding
J1210CA401 - Rear Red/Cherry Stripe tS Molding
My 2017 JDM tS Build
IG: @TheJonRZ
JonRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to JonRZ For This Useful Post:
chaoskaze (02-21-2018), tfp (02-27-2018)
Old 02-21-2018, 05:25 AM   #2473
stlgrym3
anyone has the part number for the Brembo BBK comes with the TS or PP?
stlgrym3 is offline   Reply With Quote
Old 02-21-2018, 07:40 AM   #2474
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
There are several parts numbers as it's not sold as a kit and the whole thing will set you back over $4k all in. You're better off buying aftermarket IMO. But, if you really want the part numbers, let me know and I'll look them up for you when I get a chance.
trippinbillies40 is offline   Reply With Quote
Old 02-21-2018, 07:44 AM   #2475
stlgrym3
$4k is still cheaper than getting front and rear Brembo or Stoptech BBK right?
Old 02-21-2018, 08:33 AM   #2476
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
http://www.ft86club.com/forums/showthread.php?t=109786
illmatic is offline   Reply With Quote
Old 02-21-2018, 10:53 AM   #2477
trippinbillies40
Drives: '22 WRB
Ok let's do this...
Front Caliper Mounting Bracket: 26261FE000, $53.25 x2
Front Mounting Bolt: 901120131, $4.32 x 4
Front Left Caliper: 26292CA060, $699.95
Front Right Caliper: 26292CA070, $699.95
Front Pads: 26296FE100, $299.95
Front Rotors: 26300FE001, $433.77 x2
Front Rotor Shield Right: 26290CA020, $22.27
Front Rotor Shield Left: 26290CA030, $22.27
Rotor Shield Bolts: 901000162, $1.08 x6
Front total: $2742.19
Rear Caliper Right: 26692CA060, $649.95
Rear Caliper Left: 26692CA070, $649.95
Rear Pads: 26696FG000, $239.95
Rear Mounting Bolts: 901000326, $3.37 x4
Rear Total: 1553.33
Front and rear total:$4295.52
It appears that hoses and rear brackets and rotors are the same. This is all MSRP, so you could probably get it all a bit cheaper by shopping around. Keep in mind you'll need wheels that clear the calipers, as well as a couple quarts of brake fluid.
The Following User Says Thank You to trippinbillies40 For This Useful Post:
Veloist (02-21-2018)
Old 02-21-2018, 01:34 PM   #2478
derekbrz24
derekbrz24's Avatar
Drives: 2017 Subaru BRZ WRB PP
Does anyone have part numbers for the mesh grills on the tS?
derekbrz24 is offline   Reply With Quote
it sucks to be broke, sti omg!
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 06:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 11:30 AM
