#4537 | |
You cannot undo the damage that has resulted from that tune, and you will have other issues, including those you've mentioned above (although most are not pertinent to tracking). My recommendation remains that you avoid a first year car completely. |
#4538 |
Drives: Miata
Oooh. First I have heard of that. Seems like a bad thing. Thanks for bringing it up.
Okay. Are all of your concerns addressed with a 2014? |
#4539 |
#4540 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I don't plan to sell my car to update and will just get a newer powertrain when this one fails. But wondering if any steps might help prolong that lol |
#4541 | |
In your case, just address the issues as it happens; my previous statement is primarily for people buying used cars. |
#4542 | |
#4543 |
Drives: 86
Hi mike do you have the part number for HC800 for front and rear? in Australia here we have gt and gts model and the part number for the rear seem to be R914-HC800 and R916-HC800 respectively. Front seems to be F914-HC800. However, I'm not sure if thats correct and just wanna make sure i order the correct parts.
Thanks in advance, Brian |
#4544 | |
I don't recommend you attempt to track on the HC800 at all. |
#4545 |
Drives: Crapcan
#4546 |
Better to have more pad than you need to grow into, than have a pad that you'll outgrow, and effectively have just paperweights.
#4547 |
Drives: 2016 FR-S
What tires to run in SM class? I am currently on RE71s, should I stick with it ?
#4548 |
Drives: 2014 Subaru BRZ
SM allows Hoosiers, but if you don't want to go all the way to slicks then stick withe the Bridgestones.
#4549 |
Has anyone done a comparison of Harry's Lap Timer with phone GPS compared to an external or AiM? I will be buying Qstarz before my next track day but am curious/trying to settle an argument lol
#4550 | |
Drives: 2013 Scion FR-S Firestorm
IMO, for out right timing, Harry's and a modern smart phone do a surprisingly good job. Where it falls short, is when you export the data and try and work with it. The data overlay is improved if you use an OBDII dongle, but when you're dealing in 0.1, between on/off throttle, the amount and frequency of data points being collect by Harry's falls short. I remember looking at data collected at the bus stop at WGI 2 years ago, trying to compare a brake trace [Edit: between multiple laps] (Harry's doesn't, at least not on a twin) and looking at throttle tip in, there just wasn't enough data points to really do a proper comparison. EDIT: My ultimate conclusion is this: Harry's Lap Timer does a good job if you want to time yourself. And it will give you relatively accurate lateral g loading. You can look at your laps and see where you can maybe push a bit harder here or there. Where it falls short is if you want to actually work with that data and compare multiple laps and really see where you're gaining or losing time. Last edited by jjaisli; 02-12-2018 at 01:06 PM. |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
