Old 01-20-2018, 12:38 PM   #43
gtengr
Drives: 2017 BRZ
Originally Posted by Kodename47 View Post
May I put forward the Beatrush Underpanel. No cutting, modding or replcing of the bonnet required. Proven to work, might even add downforce if claims are correct. Pulls heat directly past and away from the manifold too. Only downside is that it's not cheap, but still cheaper than a modded or aftermarket bonnet.
My understanding is that nothing should be vented anywhere to the underside of the car if it can be avoided. Using low pressure under the car to extract would incrementally increase the pressure under car. That the engine bay air is heated might make it worse. If anything, I think a few holes in the stock under panel need to be patched up once venting to the top side is done. It's probably less of a factor in stock form, but I want to eventually have the bottom as flat as I can reasonably make it.
gtengr is offline   Reply With Quote
Old 01-20-2018, 12:51 PM   #44
gtengr
Drives: 2017 BRZ
Originally Posted by makinen View Post
Under hood pressure should be counted for the venting. Pressure difference really makes air move.
I did an experiment for the vent at the cowl area on 2016. With the help of a Gurney flap, at least it blows out some air. I guess a blocking vertical barrier that divides low pressure zone and high pressure zone could help more.
I know it cannot blow out as much air that hood vent can. But could be better than nothing.
Very nice! Did you just remove that plastic end piece and replace it with a grill? Any further cutting involved?
Or do make your own like this, @gtengr .
Looks functional for venting, but not the route I want to take.
Old 01-20-2018, 05:13 PM   #45
Kodename47
Kodename47's Avatar
Drives: UK GT86
To quote their website:
The under panel improves the rectifying effect on the bottom surface of the body during high speed driving and generates downforce.
Also suppresses the flow of air caught in the engine room.
By installing a ventilator, it efficiently discharges the heat of the engine room and prevents heat up of the engine.
We also made use of 2.0 mm thick aluminum material for weight gain.
It's certainly smoother than the DIY posted above.
http://laile.co.jp/carparts/cooling/under_panel/
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-20-2018, 05:45 PM   #46
gtengr
Drives: 2017 BRZ
That one is smoother a lot smoother, but still not the route I want to take. It might reduce lift on a stock car, but I'm confident it would be detrimental with a flat bottom.
The Following User Says Thank You to gtengr For This Useful Post:
Kodename47 (01-20-2018)
Old 01-20-2018, 06:45 PM   #47
Kodename47
Kodename47's Avatar
Drives: UK GT86
Would be interesting to see if the underbody aero would be massively affected. For example blown diffusers utilise the heat and extra airflow under the car, so it's not always a bad thing. It does depend on some factors though. You might find it actually helps improve airflow coming under the front bumper for example, splitter or not. I'd imagine having no lower splitter would see the front bumper create way more of an issue than this plate.
The idea of a gurney flap at the rear of the bonnet is interesting. I wonder if it need an actual wing shaped flap or just something to kick up the airflow away from the cowl. If the latter, it would be cheap to implement with those universal spoiler lips available on eBay etc.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-20-2018, 09:08 PM   #48
Gunman
Drives: 2019 Mazda Miata RF
Agreed, you want to evacuate the underside, and keep the jet moving/accelerating, to create downforce. Front and side splitters/skirts work to keep the air out. I'd avoid any non-essential under body openings, which can cause turbulence. We used to seal around the air jack openings, on the GTLM/GTD/GT3 Viper. Flat smooth bottom is good. We did have openings under the exhaust, but also played with the location and shape to minimize the effect, and maintain the center jet.
The Following User Says Thank You to Gunman For This Useful Post:
gtengr (01-21-2018)
Old 01-20-2018, 11:36 PM   #49
makinen
makinen's Avatar
Drives: Toyota 86
Just removed parts.
In the below pictures, I removed both parts at the ends of cowl area. But what I am actually using are only rubber parts removed from them. Those rubber parts which I colored in orange in the above diagram are for the fully opened posion of the hood.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
The Following User Says Thank You to makinen For This Useful Post:
gtengr (01-20-2018)
Old 01-20-2018, 11:48 PM   #50
gtengr
Drives: 2017 BRZ
Whether it's a massive effect is hard to say imo. I'm pretty sure the blown diffuser effect is more due to the exhaust gas having a higher relative velocity than the air in the diffuser than it is the heat. The engine bay heat doesn't really flow so much as it needs extracting, and in an FR layout it would have to be dumped at the front of the car. So it slows that air, which in turn means slower air through the diffuser.
Old 01-20-2018, 11:52 PM   #51
gtengr
Drives: 2017 BRZ
Just removed parts.
Attachment 162124
Cool. I think I'll drill out those plastic pieces and leave some of the material there to cover up the fender bolt and some of the hinge. I'm going to wait until I get the Edelbrock on (waiting for the 2017 kits) before doing anything so that I can check it with datalogging.
Old 01-21-2018, 12:08 PM   #52
Gunman
The exhaust was being used to deflect the rear tire wake away from the diffuser, to increase its efficiency, OR re-energize the flow at the back of the diffuser. The downside, was the on/off effect based on the engine rpm, engine mapping, or throttle control entering the corner was key, to keep from upsetting the aero balance.
Way more complicated, than what anyone would get to work on a street car.
Old 01-21-2018, 04:30 PM   #53
Launcher
Drives: Subaru BRZ Limited 2013
Well, Launcher, I must ask ....... why do you want either one ..... ??
* to make the hood lighter ..??
* to allow hot air to escape the engine compartment .. ??
* to look cool ..... cause CF ..??
* other
Sorry for the late response, this thread took off into several different ways haha
Mostly just for looks at this point. I only track my car like once or twice a year and store it in the winter like right now.
The CF hood style looks the best and was thinking about just painting it black instead since I am not sure I would like the rest of the car black and then hood only CF
Launcher is offline   Reply With Quote
The Following User Says Thank You to Launcher For This Useful Post:
humfrz (01-21-2018)
Old 01-21-2018, 05:20 PM   #54
....... and that is the more correct answer.
Yep, this thread, like most, has many tangents spinning off of it .....
Old 01-21-2018, 08:19 PM   #55
norcalpb
norcalpb's Avatar
I learned new things in this thread...
The Following User Says Thank You to norcalpb For This Useful Post:
humfrz (01-21-2018)
Old 01-23-2018, 11:24 PM   #56
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by NRXRaptor View Post
If you are going to paint a carbon fiber hood it defeats the purpose to me. From what I know most consumer level carbon fiber bits are carbon fiber molded/stuck onto a hood shaped piece of fiberglass. My 2 cents
It's a wet carbon hood, most likely with a fiberglass underside or core. The point is moot unless your replacing a car make with a heavy steel hood (pre-90's.)
HELP: hood pins/latches on carbon fiber hood scubie.brz Cosmetic Modification (Interior/Exterior/Lighting) 1 05-13-2016 01:10 PM
Custom GT 300 hood vents/heat managment kuczynskika Cosmetic Modification (Interior/Exterior/Lighting) 7 10-21-2015 01:00 PM
Florida: Trade Silver hood for Black hood 555 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2015 11:52 AM
