#29 |
Yep. Base warranty
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (01-10-2018) |
#30 |
Yep. Base warranty
![]() Note the disclaimer though. If the TOB goes bad completely it is beyond the scope of "noisy" and they could deny any other related work.
#31 |
Mine started with a screeching sound on a cold morning when lightly pressing the clutch. Presing farther on the pedal loaded it up enough for the sound to go away. Releasing it again and then lightly pressing would produce the screech again. But after driving for a few minutes it would heat up enough to clear up. It was obvious it was the TOB so I tackled it that weekend. The clutch pedal felt much better after replacing it but this is the case after almost any clutch service where you re-grease everything. The improved feel is probably more the grease than the TOB.
| The Following User Says Thank You to ermax For This Useful Post: | humfrz (01-10-2018) |
#32 |
What did the quill look like. Was it all scored?
#33 |
| The Following User Says Thank You to ermax For This Useful Post: | Ultramaroon (01-10-2018) |
#34 | |
#35 | |
| The Following User Says Thank You to ermax For This Useful Post: | Tcoat (01-10-2018) |
#36 | |
#37 |
Drives: 2015 Scion FR-S 1968 Camaro BB402
Been doing some research, I think the lack of proper lubrication to the TOB (courtesy of Toyota) and the fact that there is no f-ing clutch fork return spring to keep the bearing from moving around on its own makes the perfect storm for this issue. Thoughts?
#38 | |
The design of the TOB is not any different from TOBs reaching back through all makes even into the 1930s. 1935 Ford
| Popping, Crunching and Creaking Noise | MyEvilMonkeys | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 07-22-2020 01:50 PM |
| Hum/whine when decelerating | GeeTee86 | Issues | Warranty | Recalls / TSB | 10 | 08-11-2016 01:01 PM |
| White smoke decelerating | azynneo | Engine, Exhaust, Transmission | 6 | 07-23-2016 11:14 AM |
| need help with a crunching sound | puravida | Issues | Warranty | Recalls / TSB | 6 | 08-12-2014 08:16 PM |
