go_a_way1, MisterSheep
Old 01-02-2018, 11:52 AM   #18145
arxm
Drives: 2013 FR-S, 2023 BRZ
The first place I would check is the oil filter. I'd take it off and make sure only one gasket is in place (and only one) and that gasket was not squished out. Also, make sure the filter was not cross threaded.
The second place I would look would be at the drain plug ....... are you sure you don't have two crush washers on it and one of them is squished out ..??
im 110% positive theres only 1 washer on the drain plug as the original one fell into the oil as i was draining it lol, when it warms up a bit i will go check the oil filter
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 01-02-2018, 12:48 PM   #18146
DarkSideFRS
Drives: 2013 pearl white FR-S
santa came and dropped these off...
DarkSideFRS is offline   Reply With Quote
The Following User Says Thank You to DarkSideFRS For This Useful Post:
Lonewolf (01-02-2018)
Old 01-02-2018, 01:12 PM   #18147
When is that going to be ...... spring time .........??
Old 01-02-2018, 01:30 PM   #18148
Originally Posted by Darth Khan View Post
Gave her a little Christmas present, added the following door latch cover.
Merry Xmass and A Happy new year to all BRZ/FRA/8's. May the road gods protect you from the synaptically challenged road user.
Attachment 161508
Well, now, don't that just beat all mods .........
Old 01-02-2018, 01:34 PM   #18149
Tell me you haven't put the tire on the rim yet .......
Old 01-02-2018, 01:38 PM   #18150
Darth Khan
I think therefore.....
Darth Khan's Avatar
Drives: Toyota 86 860 Halo White (Manual)
LOL< I'm working my way up to an engine swap
May the N.A. force be with you.
Darth Khan is offline   Reply With Quote
The Following User Says Thank You to Darth Khan For This Useful Post:
humfrz (01-02-2018)
Old 01-03-2018, 01:24 PM   #18151
Leonardo
Country Boy 4 Life
Leonardo's Avatar
via Imgflip Meme Generator
Just received my new thicker gaskets that have adhesive on one side! Yeah! Hopefully these will stop my trunk from being a pond....
I LIKE TIRES!
Old 01-03-2018, 01:44 PM   #18152
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
This is the key to your success: https://www.amazon.com/3M-08008-Blac...7&sr=8-1-spons
Originally Posted by humfrz
I'm old and lazy
The Following 3 Users Say Thank You to Clipdat For This Useful Post:
guybo (01-04-2018), Leonardo (01-03-2018), Teseo (01-03-2018)
Old 01-07-2018, 07:55 AM   #18153
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I got rid of the stock Primacy's and got MPSS today. I haven't had a chance to drive much but on the way home I felt like I was riding on Flintstone rock tires- they put in 37 psi! We'll see how the ride is today with 31. I went with 225/45/17
MPSS were my first choice but expensive, so I originally planned to go with BF Goodrich Sport Comp 2 (great price for a good tire). But one place I went to tried to sell me 3 year old tires (ALWAYS read the DOT date on the tires!) and the next place had a hard time finding the Comp 2's. So I decided to spend too much and get the best.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
Leonardo (01-07-2018)
Old 01-07-2018, 08:34 PM   #18154
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Trying something different. Added the rear window window visor, and moved my third brake light to outside the car.
I LIKE TIRES!
Old 01-08-2018, 09:53 AM   #18155
Roth
Roth's Avatar
Drives: 2013 Gt86
Nice mod, can you tell us more about it?
Roth is offline   Reply With Quote
The Following User Says Thank You to Roth For This Useful Post:
Leonardo (01-08-2018)
Old 01-08-2018, 01:46 PM   #18156
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I made it from stuff laying around, like all my mods... I am cash poor and "stuff-laying-around" RICH! Plus, I work with LEDs and enjoy soldering.
The wire to the light is ran up the side of the window behind the small rubber trim.
(window window LOL!!!)
Currently the wire is quick ran through the tail light hole into the trunk. If I decide to keep it this way, I will run the wire more elegantly through the trunk lid wire rubber boot.
Installed my tail light gaskets too. Thanks to @Clipdat
Used this like you suggested!!!
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Roth (01-09-2018), Ultramaroon (01-08-2018)
Old 01-08-2018, 02:34 PM   #18157
Clipdat
Proud of BOXER
Clipdat's Avatar
How did it go? When I used it I just applied it to the back of the tail lights, and then pressed the gasket down onto it and let it set for a while before installing.
That stuff stinks so bad, I made the mistake of doing mine indoors.
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
Leonardo (01-08-2018), Ultramaroon (01-08-2018)
Old 01-08-2018, 02:41 PM   #18158
Leonardo
Country Boy 4 Life
Leonardo's Avatar
It went well. I have a car port, thankfully, cause this stuff probably causes cancer. Anyway, it has not really rained yet to test the seal. I'll update if my trunk stays dry or begins to fill with water, again.
Thanks for the help!
Ill add this for others...
Tip: I think it's a good idea to wear rubber/nitrile gloves when using this stuff.
I LIKE TIRES!
Clipdat (01-08-2018), Ultramaroon (01-08-2018)
