Old 01-11-2017, 10:45 AM   #113
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Before installing my supercharger and running 20 weight oil I would see oil pressure on a hot engine scary low. 220 degree oil temp, 3 lbs oil pressure at idle.
When getting tuned for the supercharger I had my tuner raise my idle RPM from 750 to 950. Now my oil pressure never drops below 20 psi at idle.
This is with 5-30 oil.
Lunatic is offline   Reply With Quote
The Following 4 Users Say Thank You to Lunatic For This Useful Post:
Boris_Petrov (08-28-2019), solidONE (01-12-2017), Tcoat (01-11-2017), Ultramaroon (01-11-2017)
Old 02-13-2017, 12:40 AM   #114
HotlavaFRSGT86
Keep ICE alive+manuals
HotlavaFRSGT86's Avatar
Drives: 2015 Hot Lava 6 spd
Oil pressure
Wow yours really dipped to 3lbs warm? Shit mine only dips to about 8lbs at idle, runs about 120-125 cold and 40-60 psi under normal driving conditions warmed up.
If your not first your last - Ricky Bobby
HotlavaFRSGT86 is offline   Reply With Quote
The Following User Says Thank You to HotlavaFRSGT86 For This Useful Post:
Surok (01-01-2018)
Old 02-13-2017, 01:17 PM   #115
Lunatic
Lunatic's Avatar
Toyota specs call for 7 psi @ 172 degrees at idle. So you know oil pressure will go lower as engine warms up.
The Following User Says Thank You to Lunatic For This Useful Post:
Surok (01-01-2018)
Old 04-14-2017, 09:10 PM   #116
SoCalArgento
Drives: 2014 Argento FRS
Does anyone know if it's normal for for oil pressure gauge needle to flutter +- 1-2 psi during highway cruising or right after off throttle? I recently installed a Defi gauge with pressure sender attached to top of block by AC unit. Doesn't seem to be leaking or anything.
This is first time using an oil pressure gauge.
In regards to oil pressure I'm running 0w20 with pressures around or slightly below 10psi at around 185 F and around 40-47psi highway at 190F.
SoCalArgento is offline   Reply With Quote
Old 01-01-2018, 06:50 PM   #117
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
i came to this thread because i saw like 8psi at 500rpm.. i was like :O
I have the billet oil pump gear too, to defend against it breaking the stock item.
Surok is offline   Reply With Quote
Old 01-02-2018, 03:00 AM   #118
Lunatic
Lunatic's Avatar
I solved my low idle oil pressure by raising my idle rpm from 750 to 900 rpm. Now idle oil pressure stays above 20 psi.
Old 01-02-2018, 08:48 PM   #119
Did you post this just to see if we were payen attention .....??
Old 01-02-2018, 08:53 PM   #120
Lunatic
Lunatic's Avatar
Yup! Ya caught me.
humfrz (01-02-2018)
Old 01-02-2018, 09:04 PM   #121
Yup! Ya caught me.
Yep, raising the idle will increase the oil pressure ...... most of the time ....... cept on splash oiled type, lawn mower engines .....
Old 01-02-2018, 11:34 PM   #122
Lunatic
Lunatic's Avatar
Actually all kidding aside I raised the idle rpm because seeing 3 and 4 psi oil pressure at idle with a hot engine bothered me. I feel better seeing 20 psi now.
Old 01-03-2018, 01:04 AM   #123
Yep, 20 psi is a much more comfortable number to see.
However, that reading of 3-4 psi just may have been beyond or at the limit of detection for your instrument and the pressure was actually 7-9 psi ....... jest tryen to make you feel better .....
Old 01-03-2018, 09:31 AM   #124
Lunatic
Lunatic's Avatar
Very possible, I'm just using an old school mechanical gauge. But it read pretty close to the Toyota specs of 7 psi @ 172 degrees, and being in southern CA. my oil temp reads 200 most of the time I knew it had to be lower than 7 psi. So yes, now I feel better with more oil pressure. An easy fix for me. I wish the top end pressure drop was as easy to fix.
Old 01-03-2018, 02:52 PM   #125
Get a big fucking oil cooler. I can hook you up with a bill of material for my setup but finding a diverter valve might be the tricky part. You wouldn't need it unless you daily yours.
I can maintain my engine oil temp below 190 F for an unlimited duty cycle. I cut back on the flow when I'm cruising.
http://www.improvedracing.com/setrab...ler-p-247.html
Old 01-03-2018, 03:10 PM   #126
Ultramaroon (01-03-2018)
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 05:54 PM
Mid range really lacking goli5oda Electronics | Audio | NAV | Infotainment 4 08-19-2013 11:27 AM
Range on a tank of Gas! crank Southern California 28 02-10-2013 05:04 PM
Cruising Range? skoodge Scion FR-S / Toyota 86 GT86 General Forum 4 05-25-2012 03:31 AM
UK Price range £25-£32k!? ZeeSpeed Scion FR-S / Toyota 86 GT86 General Forum 56 11-27-2011 03:11 PM
