Old 08-01-2017, 08:51 PM   #15
Ernest72
Originally Posted by JMon85 View Post
I like my Cosworth
Second that!
Old 08-01-2017, 11:21 PM   #16
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
I like my Cosworth
I have a Cosworth drop-in filter in my 2013 FR-S and, unlike others previously posting in this thread, I definitely felt like my car revved more freely than with the OEM filter. Cosworth has a fitment for 2017 cars, so I highly recommend giving it a shot.
RJasonKlein is offline   Reply With Quote
Old 08-02-2017, 01:53 AM   #17
churchx
churchx's Avatar
Drives: 2014 GT86
Aaand again. Why bring up pre-MY2017 car as a supportive argument, if it's already been mentioned that one of MY2017 OEM improvements over those older ones is stock airfilter of less pressure drop?
Old 08-02-2017, 03:04 AM   #18
RJasonKlein
Understood and fair point - I sure hope the original poster reads this clarification, because it would be terrible if my misleading comments steered him wrong...
Old 08-07-2017, 12:35 AM   #19
Blue Bird
Blue Bird's Avatar
Drives: '14 BRZ
I have a '14 model and was planning to get a K&N drop in filter. But I read that it will run my engine run lean(er)?
https://www.reddit.com/r/ft86/commen...begin/dkzwzrf/
Can someone give me more insight on this? If he is right or not?
Blue Bird is offline   Reply With Quote
Old 08-07-2017, 03:36 AM   #20
churchx
churchx's Avatar
Drives: 2014 GT86
Blue Bird: Drop-in filter shouldn't affect AFR.
What were mentioned in your linked post as doing that, were intakes, that has such shape/size/MAF sensor placement, that allows passing more air while making MAF sensor by it's stock calibration misdetect as lesser air volume, thus when ECU tune adds in fuel amount matching those mis-readings, result is leaner air-to-fuel ratio. More power, but also less knock safe. Better doing proper ecu tuning, not hacking-around. It happens though, that after proper tuning for new bolt-ons, taking into account changes to MAF sensor readings, large share of these "hackish gains" by artificial leaning ARR are diminishing, making those parts to add way less power, by price/performancy. There are also such intakes kits, that had goal when designed, to not change stock MAF sensor readings (IIRC Grimspeed & TRD ones should be such), but of course they have less "gains" with stock tune, thus may look less competitive.
Changing filter to less pressure-drop/less resistive - leaves everything else stock. Airbox/inlet tube/MAF sensor placement. Even if air with everything rest being same can flow through easier, MAF sensor will detect that larger volume of air, and ECU tune will know to add more fuel in to reach targeted AFR.
Old 12-24-2017, 04:13 PM   #21
Lonewolf
Lonewolf's Avatar
Drives: Moped
It's a long shot, but does anyone have before/after dyno comparisons of stock 2017 mt car with stock filter vs. same car with any aftermarket filter? I know that 1-3 hp variations could be chalked up to a host of factors...just curious if anyone has any data
Old 12-24-2017, 04:53 PM   #22
justinco
justinco's Avatar
Drives: 2022 GR86
Best I have is stock 2017 BRZ and then with bolt-ons and OFT. You aren't going to see any change by just throwing in a filter. I think the Blitz is still the only one available for the 2017 MT cars.
[ame]http://www.youtube.com/watch?v=2qY6YKnH8jI[/ame]
[ame]http://www.youtube.com/watch?v=iWcGW-wlOEg[/ame]
justinco is offline   Reply With Quote
Old 12-24-2017, 05:27 PM   #23
Somerandom18
Drives: 2017 manual BRZ
I've done high flow drop in filters in a few cars and honestly one in the 2017 made absolutely no noticable difference compared to others. Wasn't surprised at all though considering the huge surface area increase over previous years for the stock filter.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 01-01-2018, 12:09 PM   #24
Zentec
Drives: 2017 Toyota 86
Dropping in a K&N and putting nitrogen in the tires has been one of my first things I have done on my last 4 cars. Although I have not done the filter on my 17 yet. I have noticed little differences in response time of throttle. Even with stock exhaust with those 2 I have found an increase in mpg. I live in a severe weather climate and it helps to be able to clean my air filter rather than paying 50$ from the dealer for a new one. I like spending money wisely and only once. I’ve done this on several boxers with full exhaust and tunes turbo and non turbo. Although I have only tried fram air hog and k&n and the k&n was better. For me it’s something that is cheap and improves driveablity and mpg when done together but as for hp gains only it’s almost none of any. But really show me a drop in or bolt on that cost 50$ improves hp and trq with realistic results. There is none or everyone would have it. As for what One is better it’s up to your own opinion. Find one that you like and drive happy
Zentec is offline   Reply With Quote
Old 01-01-2018, 12:37 PM   #25
Zentec
I don’t get why we have dinky little air boxes any way on this car. The stock air box on the s2k was huge on top of that it was a massive cone filter. They should have adapted that or at least built off of it or improved it it could really help. O and no need for a stupid sound tube if you wanted louder sound you just take off the top cover to the air box now open ram intake
Old 01-01-2018, 01:40 PM   #26
Teseo
Drives: frs
Ecu will adjust the changes, until you get tune and will see the benefits otherwise is a placebo effect
Old 01-01-2018, 02:23 PM   #27
JD001
JD001's Avatar
Drives: Subaru BRZ
I had the HKS drop in filter until a few weeks back when I had the car tuned and replaced the HKS with a Takeda CAI. A tune and CAI is the way to go as the difference is amazing.
2017, air, filter
2017 BRZ MT Drop-In Filter Drambeenie Engine, Exhaust, Transmission 23 03-03-2017 12:17 AM
Need Help With Drop-In Filter Ammunition Engine, Exhaust, Transmission 5 01-01-2014 03:29 PM
Which dry drop in air filter? DarkestBuddha Engine, Exhaust, Transmission 17 09-10-2013 12:41 PM
DIY drop-in filter? aceangel Engine, Exhaust, Transmission 18 04-25-2013 10:42 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
