Old 12-26-2017, 02:20 AM   #15
With electric power steering, fuel pump, ECU that only works within a certain voltage, DLRs always on, and all the other electric powered parts of a modern car? My money is on dead enough battery to not run before boil over. The battery doesn't have to be completely drained to shut down the car.
No EPS without alternator. Current-limited DRL? Returnless fuel system? I'll take that bet any day.
Old 12-26-2017, 02:44 AM   #16
Duh, usually when I partake in such mind altering activities, my mind does wonder about how we humans are such fragile creatures. I mean we put our very lives on a 4 3x5 pads (mostly) to stop 2 tons of rolling steel and aluminum from crashing or making us into human pancakes.
That's exactly the reason why I always thought we should have rubber roads and concrete tires .........
Ultramaroon (12-26-2017)
Old 12-26-2017, 02:47 AM   #17
n0thing
Drives: Subaru BRZ
Well, now, actually he is correct ....... the drive belt breaks - the alternator quits working - the battery runs out of electrons - the spark plugs won't fire - the engine quits running ........
Oh, come on. Which happens first by a long shot, boilover, or dead battery?
Quit yanking my chain, old man.
Thanks @humfrz @Tcoat
It depends on the driving condition too. Whether it's at the track pushing the engine to redline with extreme temperature, or regular city driving with bumper to bumper traffic. Either way though, the vehicle will shut off
n0thing is offline   Reply With Quote
The Following User Says Thank You to n0thing For This Useful Post:
humfrz (12-26-2017)
Old 12-26-2017, 02:53 AM   #18
What are you talking about? On what facts are basing this horse shit?
Old 12-26-2017, 03:05 AM   #19
OK, this calls for an easy experiment.
We will need 4 participants.
Each with a twin.
Remove the serpentine belt.
Start the car.
Drive the cars at 45 MPH till they quit running.
Read the temperature gauge ....... read the voltage of the battery.
Charge the battery and start (or try to start) the car.
If it starts and runs OK, @Tcoat , @n0thing and humfrz are correct ..... @Ultramaroon is wrong.
OK, @n0thing ...... you go first and report back.
humfrz - retired scienteeeeeest ...........
Old 12-26-2017, 03:08 AM   #20
Watch out folks ol Ultramaroon is getten grumpy tonight ........ his stocking hanging from the fireplace must have been a bit light this year ......
Old 12-26-2017, 03:12 AM   #21
Been there, done that. I don't talk shit. I talk from experience.
Old 12-26-2017, 03:15 AM   #22
OK, let's see the raw data from your experiment ...... let's see if will stand up to a pier review .......
Old 12-26-2017, 03:22 PM   #23
I'm not enjoying this. After you have disabled your alternator and driven around for a spell, let's compare notes.
Old 12-26-2017, 04:50 PM   #24
I'm sorry to hear you had a failed alternator experience ......
I feel badly that I was rubbing salt in the wound ......
Please forgive me ........
Old 12-26-2017, 05:37 PM   #25
One day months ago I removed the accessory belt to prove to myself the car would start and run on battery only. I know Tcoat was in the thread where we discussed it. I just figured you had followed along.
I know enough about the power requirements of this car, and have enough experience limping home with failed alternators on previous cars, to state with confidence that without an accessory belt, this thing will run on battery waaaaaaaaaaaaay longer than it will take to overheat.
I'm happy to discuss the topic in earnest, and admit my pu55y hurt a little when you assigned me homework.
humfrz (12-26-2017)
Old 12-26-2017, 05:51 PM   #26
I'm happy to discuss the topic in earnest?
Well, after doing some research on several batteries, it appears the average RC (Reserve Capacity) is about 60 minutes.
So, even if the FR-S battery was half that, the engine would overheat, due to the water pump not running, before the battery would run out of juice.
So, there ........ @Tcoat was WRONG !.........
Old 12-26-2017, 07:02 PM   #27
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by qqzj View Post
This is pretty new to me. All my older cars have crank-driven water pumps.
Did you actually think about what you wrote before you posted?
What did you think was driving the accessory belt, some random motor? It's all connected to the crank.
Old 12-26-2017, 07:05 PM   #28
I gave him that. I scratched my head until I worked my way back to the timing belt. I think that's what he meant.
Removing and Replacing your BRZ/FR-S Accessory Belt GrimmSpeed DIY (Do-It-Yourself) Guides 12 04-25-2019 05:53 PM
OEM Water Pump Belt Cover Philly758 Want-To-Buy Requests 2 07-07-2015 07:08 PM
Leaking water pump DJCarbine Issues | Warranty | Recalls / TSB 11 05-13-2014 06:59 PM
Water pump Micene Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-08-2013 08:57 AM
accessory belt pensioner pulley 7thgear Issues | Warranty | Recalls / TSB 4 09-24-2012 11:19 PM
