Old 12-22-2017, 01:02 PM   #1
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
Paint peeling and rust on passenger side reinforcement brace
I was installing Berk front pipe yesterday and noticed paint peeling and rust on the left reinforcement brace thats just above the catalytic converter in the front pipe in the engine bay.
I always had stock pipe, so not sure if it's because of heat. Anyone else have experienced or seeing something like this. It's only on left brace and peeling is only confined to this piece that's welded to the side rail and firewall.
I looked online and it's called reinforcement toe board (p\n 51630CA1709P)
Note: It looks oily beaucse I got it krown rust proofed a short while ago.
Sent from my Pixel using Tapatalk
Sideways is offline   Reply With Quote
Old 12-22-2017, 01:45 PM   #2
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
That looks like a pretty clear cut case of corrosive liquid damage. Where it came from, I have no idea, but the battery is right above that area...I'd start there.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following 2 Users Say Thank You to venturaII For This Useful Post:
Lorico (12-26-2017), Sideways (12-22-2017)
Old 12-22-2017, 03:25 PM   #3
Brake fluid.
Old 12-22-2017, 03:35 PM   #4
Sideways
BRZZZZZ
Sideways's Avatar
I looked at the battery and its clean. No corrosion on the battery tabs or anything. Going to investigate this over the weekend. Maybe its leaking or something.
Brake fluid.
That exactly what I thought also, but the reservoir, cylinder, abs all is on the other side. Hopefully I could find the source and sort it out before it gets bad.
Old 12-22-2017, 03:39 PM   #5
venturaII
venturaII's Avatar
Is there a hard brake line in that area?
FS: GTSPEC SWAY BAR REINFORCEMENT BRACE (REAR) andy86 Brakes, Suspension, Chassis 0 11-08-2017 01:20 PM
paint peeling? chipping/ rusting on fenders? nickmerronesucks Issues | Warranty | Recalls / TSB 27 12-01-2015 09:11 PM
Anyone else experience paint peeling? euroshowoff Issues | Warranty | Recalls / TSB 9 08-23-2013 12:39 PM
side foam window peeling.. marky Scion FR-S / Toyota 86 GT86 General Forum 21 01-21-2013 07:39 PM
Anyone else notice paint ripples in their passenger side door? Memphis Issues | Warranty | Recalls / TSB 19 09-25-2012 11:28 AM
