| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
The torque referred to for the steering is not the torque created by the engine. They are talking about the torque applied when you turn the steering wheel that activates the power steering. The sensors have nothing to do with torque steer. For the steering to compensate for torque steer it would need to turn the wheel on it's own. It doesn't do that.
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#16 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
+1 for tire issue and/or alignment
#17 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
#18 |
Drives: 2015 BRZ series.blue
Will switch tmrw and report back! Thanks all
| The Following User Says Thank You to covance For This Useful Post: | Tcoat (12-08-2017) |
#19 |
Tires switched. Works absolutely perfect now. Problem solved.
I am absolutely baffled by how certain that mechanic was it was an ECU issue. He owns the garage, owns other gas stations, has owned other garages in the past, him and all his employees are ASE certified etc etc, and he literally talked my ear off for 10 minutes yesterday about how there is no way it is a tire issue. Thanks fam! |
| The Following User Says Thank You to covance For This Useful Post: | Tcoat (12-09-2017) |
#20 | |
He obviously knows how to talk a good game with uneducated car owners. |
| The Following User Says Thank You to Grady For This Useful Post: | Tcoat (12-09-2017) |
#21 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
A lot of cars being manufactured now use automatic braking on a slipping drive wheel to *simulate* limited slip the way it should have been done.
That's the computer relation he may have latched onto. If your mechanic didn't know that we have an actual mechanical LSD that may be what threw him. They are very uncommon on the great majority of garden variety people movers he's used to servicing.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | Ultramaroon (12-09-2017) |
#22 |
Well said, @bcj. I still can't excuse the mechanic for referring to a torque sensor unless he was referring to Torsen, in which case I am even more convinced that he was in full bullshit mode. SMH. Fuck that clown.
#23 | |
Huge E85 fan!
Drives: 2016 Scion FRS
Of course the pull is from the mismatched tires. Often times, the cheapest way is is the most expensive way out. You have to track down what the mismatched tires messed up. |
#24 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (12-09-2017) |
#25 | |
#26 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (12-10-2017) |
#27 | |
Mismatched tires on the rear were probably only there for under two months with <10 miles a day most days. |
#28 | |
Junior Pizza Joe
Drives: 2017 BRZ Limited Manual WRB
Scooby-Doo: Scooby-Dooby-Doo!
Shaggy: And like, Shaggy too. |
| Torque app problem | Mikeez | Issues | Warranty | Recalls / TSB | 20 | 10-25-2014 05:12 PM |
| Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 09:11 PM |
| Question on sensor placement for the Torque app. | zooki | Engine, Exhaust, Transmission | 2 | 01-01-2014 06:20 PM |
| Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? | Acree | Engine, Exhaust, Transmission | 2 | 08-26-2013 07:39 PM |
