Old 12-07-2017, 12:55 AM   #1
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Automatic Transmission Change.
(THE TITLE SHOULD BE AUTOMATIC TRANSMISSION FLUID CHANGE, MY BAD!)
Hey pals, back at it again with another odd question.
Cars currently at 46k Miles and at 50k I plan on scheduling the first Trans and Diff fluid change.
A local company, "Ptuning" of Manassas, VA has quoted me at $100 + Fluid Cost for both my diff and transmission.
Is there any precautions you guys would recommend me taking? I'm extremely nervous to have anyone messing with my gearbox and all but I have to do it eventually. Ptuning has a good reputation with the twins.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 12-07-2017, 09:10 AM   #2
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Yes, PTuning does have a good reputation although I have not personally had work done there. That said, if they are going to do the Trans fluid change by the book (up to temp, drain and overfill 3X, final fluid level adj. blah blah blah) and not just drain the pan and replace what was drained....then yeah, have them do it. The Diff fluid change is just a bonus!
BirdTRD is offline   Reply With Quote
Old 12-07-2017, 10:47 AM   #3
rns294
Drives: 13 BRZ
PTuning is one of the best garages in the country that you could take an 86 to IMO. My only gripe would be that I think they are a little expensive, however if you want quality you have to pay for it.
If you want a second option you can try Pure Automotive in MD. I would say they are on the same level as PTuning but I have not personally been to them.
rns294 is offline   Reply With Quote
The Following User Says Thank You to rns294 For This Useful Post:
VoltsFRS2013 (12-07-2017)
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 08:55 PM
found congee CANADA 0 12-04-2017 07:57 PM
AUTOMATIC transmission fluid change DIY?? qijian DIY (Do-It-Yourself) Guides 3 08-31-2017 09:34 AM
Can I change the shift nob on the automatic? chenshuo BRZ First-Gen (2012+) — General Topics 6 12-19-2012 02:19 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
