#141 |
It also replaces the guides which seems to help the squeal a lot.
#142 |
Drives: 2019 BMW ///M4
Are these guides the same as "stabilizer bars"?
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#143 |
Yes in the weather strip TSB.
The window freezing TSB replaces the actual lifters. I had both done at the same time and they were pretty sure it was the stabilizers (guides) causing the squeal.
#144 |
Drives: 2013 frs
Damn....i suppose a visit to a dealer is in order, i recently had my drivers window seal replaced on my 2013, It was folding on itself and allowing water in. Ever since i had this car from around 1800 miles the windows squeaked from the auto roll up and down,kinda just ignored it for awhile, now they both make a terrible noise going up and down. Windows also get frozen stuck very easy.
#145 | |
#146 |
Drives: 2013 frs
Ah ok seems to be a different issue then i was imagining with mine, The way i took the window freeze comment was from ice. Will post about what the dealer decides to do with mine to fix the squeal.
#147 |
It is ice for the TSB but it is ice from water that gets right down into the door. Surface ice can not be avoided and there isn't a power window made that can deal with it if it is to thick.
#148 |
I got my car back, no more squeaking noise.
N1rve
#149 |
Drives: Orange GTS
2 years ago mine started and got real bad. A Ford dealer friend said to spray a teflon dry lube into the window channels and bingo after a few ups and downs, perfect.
I used Sellys dry lube for out door blind zippers. Dupont also have one for you guys in USA but any teflon dry lube spray from a hardware store should do. Mine has had a lot of rain over the 2 years but still perfect. July 13 car. Cheers |
#150 |
Drives: GT86
Mine windows have also started to squeak after the car parked 10 hours in rain, so I did what the relevant TSB requested:
The result? On the very first rainy day, they squeaks like before. Here are the "fun" facts:
So I got tired and waxed the guides directly.... |
#151 | |
One of these days I need to pull the door apart to see how it all fits together. |
#152 | |
http://www.ft86club.com/forums/attac...1&d=1409711423 Worked for me so not sure what went wrong for Mau.
#153 | |
I looked at that TSB and I see the new weather strip part number but it looks like the stabilizer number hasn’t changed. If I understand correctly the weather strip was letting too much water pass which would damage the stabilizers. In what way does it damage them? Rust? I wish there was a cheaper way to get rid of my scratches too. |
#154 | |
Drives: GT86
To be honest, I have no idea, even the new seals are barely touch the window compared to the seals of the others cars we have. Even if the seal is fully pushed to the window, it allows water to pass trough. Would it be possible to take a picture on how the scraper seal touches the window when the door is closed (especially at the end of the windows)? It may provide a solution for me.
| Pockmarks on windows? | Dang Lad | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 20 | 09-27-2012 03:52 PM |
| Remotely lower windows with key fob? | Kido1986 | BRZ First-Gen (2012+) — General Topics | 25 | 07-16-2012 10:11 PM |
| Anyone else have problems with their windows after pushing the car too hard? | track_warrior | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 06-21-2012 11:39 PM |
| Tinted Windows | koolhawk | CANADA | 20 | 06-19-2012 07:27 PM |
| Windows 7 Theme | ToyotaObsession | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 05-28-2011 03:27 AM |
