Old 03-23-2015, 04:41 AM   #15
steveholt
Drives: 2015 BRZ Limited 6MT
Originally Posted by DAEMANO View Post
I only have the wheels removed by mechanics experienced enough to know how to re-install wheels properly without rings. No hub rings needed or used. btw, here's a more recent pic.
@CSG Mike - If you like you can add this sizing to the wheel directory now that you've taken over for Darren
I googled for almost an hour and searched on this forum but couldn't find anything about hubcentric rings interfering with the center cap for wedssport wheels
My only economical choice is discount tires, they're pretty good but were not talking custom shop good here. Serviceable but more prioritized on time and quick service.
looks very nice, i am about to place an order for 18x8.5 sa-10rs 45 offset, 5x100 just like yours. however i plan on running michelin pilot super sports 245x35x18
p.s - what exhaust are you running?
steveholt is offline   Reply With Quote
The Following User Says Thank You to steveholt For This Useful Post:
DAEMANO (03-23-2015)
Old 03-23-2015, 04:46 AM   #16
DAEMANO
Time Traveller
Discount tire should handle things ok, no worries there. The 245 MPSS will fit perfectly. Great tire, good size. TRD USA catback. Sounds really good if I do say so myself.
Old 03-23-2015, 01:15 PM   #17
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
The hub rings won't interfere with the standard domed center caps or the optional flat caps. You're good to go!
sdemo is offline   Reply With Quote
Old 04-04-2015, 01:38 PM   #18
steveholt
@DarrenDriven Adding because I don't see this width (8.5") in the directory.
WedsSport SA-10R 18x8.5 et 45
Dunlop Direzza DZ102 235/40/18
RS-R Sports-i -1.2" F/R
Flat caps are on order so shush! There's one on the front in the second image. Ghetto IK.
are you running TPMS at all on these?
if so, aftermarket or oem tpms sensors?
also, if you are, is there a bit of a gap and the tpms sensors don't sit flush/flat against the wheel?
DAEMANO (04-04-2015)
Old 04-04-2015, 06:15 PM   #19
DAEMANO
Time Traveller
OEM TPMS sensors (I had the tire shop swap them). The fit looks solid and hasn't given me any problems over the past 9 months.
Old 04-04-2015, 08:19 PM   #20
steveholt
i have the same exact wheel as you and oem tpms sensors and it sort of looks like this when i put the tpms sensor on the wheel. the fit around the seal is fine, the bottom of the sensor doesn't sit flush/flat though against the wheel
not the actual picture but this is what it looks like.
do you recall if yours was like this too? i imagine it shold be since we have the same exact wheel and oem tpms sensor?
Old 04-04-2015, 09:41 PM   #21
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
do you use hubcentric rings? if so any issues with the center cap fitment with the centering rings installed?
I have the hub centric rings on my 9.5" weds SA10R wheels.
The flat centre caps fit fine with them.
nzer is offline   Reply With Quote
Old 09-30-2015, 10:09 AM   #22
Dihudaxia
Drives: 86
Hi OP,
I was thinking of this set of wheels too. But 17x7.5 version.
I have to also run bolt on spacers and was wondering if this wheel has the stud grooves so that my bolt on spacers will be able to fit.
Do you have any pictures of the rear side of the wheel?
Dihudaxia is offline   Reply With Quote
Old 12-05-2017, 03:48 PM   #23
AutoNewb
Drives: 2014 Subaru BRZ Sterling Silver
Sorry for necroing... I'm thinking of getting this exact same setup except in MPSS. Did you have any acceleration loss going to the 235 tire??? Or actually... did you feel any acceleration loss AT ALL switching to this 18 inch setup?
AutoNewb is offline   Reply With Quote
18x8.5, sa-10r, sa10r, weds, wedssport
Wheel Directory: BBS RS-GT 18x8.0 +40 raptor87 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-09-2014 07:01 PM
Wheel Directory: BBS LM 18x8.0 +50 stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 07-08-2013 08:55 PM
Wheel Directory: TSW Nurburgring 18x8.0 +45 / 18x8.0 +35 mike_ekim1024 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 04-10-2013 07:35 PM
Wheel Directory: WedsSport Maverick 210S 18x8.0 +?? / 18x8.5 +?? quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-04-2012 01:07 PM
Wheel Directory: Blitz BRW Profile 08 18x8.0 +45 / 18x8.0 +38 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-27-2012 04:34 PM
