#15 | |
Drives: 2004 Toyota RAV-4 5M
#16 | |
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Got my car aligned with stock rear LCA. -2.6 just now FYI. 13 inch ride height. Cheers! Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender 2023 BMW M2 |
#17 |
Just heads up that Greg has confirmed that the FRS/BRZ will have to take the -0.7 a arm mod point:
http://www.nasaforums.com/viewtopic....1274&start=280 |
| The Following User Says Thank You to ja1217 For This Useful Post: | Pat (12-01-2017) |
#18 | |
so now I can either run petrol in TTD (maxxed out both points and hp wise) or run E85 to be maxxed out in TT5. Will dyno at Road Atlanta this weekend. But in all seriousness, Josh, I think you will be VERY competitive in TT5. Just some tweaks. Over dinner (actually drinks) last night Edgar and I spoke in length. It takes a heart to demod but once done, should be a lot of fun. TT4 is very taxing on our cars (external power bump etc). Lutfy
#19 |
Drives: 2013 FRS
From what I have read, it looks like whiteline rear camber bushings should be free, along with energy suspension bushings. Would you agree? Help to claw back some mod factor.
#20 | |
non metallic. I was able to get desired camber with right amount of lowering only to get .1-.2 variance after corner balancing m. After a weekend at Road Atlanta the tire wear is perfect.Lutfy
#21 |
Anyone can shine some info on Diffs? I had some serious spin at Road Atlanta this past weekend and had to eggshell T7 costing me speed
This only happens when running Hoosier R7s. There are so many options Kaaz, OSG, Cusco, Tomei and MFactory. Tomei is cost effective. Those you who who upgraded the diff, what are you using and why? Also did you go with the larger cooler? Looks like diff is a free mod. Cheers! Lutfy
#22 | |
#23 | |
I was under the impression that the Toyota Factory cup cars were on Torsen and it would suffice. But I struggled this weekend especially now that the car is dialed in and not plowing. Cheers, Lutfy
#24 |
DO we have to take the -.5 hit for "watts link, panhard bar or torque arm" if we have upgraded the traction arm?
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
#25 |
| 2018 BRZ updates | Harjotdhanota | BRZ First-Gen (2012+) — General Topics | 112 | 12-18-2017 12:55 PM |
| 2018 BRZ STI | raven1231 | FR-S / BRZ vs.... | 19 | 06-26-2017 11:39 AM |
| Where are the 2018's ??? | ~el~jefe~ | FR-S / BRZ vs.... | 41 | 05-24-2017 12:03 PM |
