Old 11-30-2017, 10:31 PM   #1
LukeFRS
Drives: 2015 FRS
tire replaced
i got a flat today and was in a huge hurry so i dropped it off at a tire shop and told them to throw on whatever they recommend to hold me over till i get new rims (next month). they put on slightly smaller tires in the front than i have in the back. i noticed that i was scraping in places i didn’t before and the ride seems a lot bumpier. Could this be because the height difference is causing the back to push the front end of the car towards the ground? or would it be the size of the front tire itself? any help would be great, i need to know if i should go back for some bigger tires because i can’t handle the ride
LukeFRS is offline   Reply With Quote
Old 12-01-2017, 12:28 AM   #2
Hello LukeFRS and welcome to ye ol forum ......
Bummer you got a flat tire ... So, it wasn't repairable ..??
So, they replaced both front tires and your old tires are still on the back .. ??
What size tires did they put on the front ..?? What size are on the back .. ??
Have you checked your tires pressures ...... maybe they overinflated the new front ones ..??
Come back.
JazzleSAURUS (12-01-2017)
Old 12-01-2017, 12:25 PM   #3
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
@humfrz gave you a great place to start. It's possible other damage occured with the flat, but it's likely the sizing is off. If you have a bigger tire in one corner it will push the opposing corner down a bit more.
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
humfrz (12-01-2017)
Old 12-01-2017, 01:05 PM   #4
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Can you read the tire size out for us? Should be on the wall of the tire, three numbers followed by a slash and then two more numbers. i.e. 180/40 or whatever.
Old 12-01-2017, 01:48 PM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The wrong size tires can cause damage or other problems. If you have 1 odd size tire you need to take care of it ASAP. Even if you have a new tire and a worn tire on the same axle that small difference in tread can cause issues. And never mix different tire makes and models. This car should have a square set up unless you have done specific modifications
guybo is offline   Reply With Quote
Should I get my HPFP replaced? hmong337 Scion FR-S / Toyota 86 GT86 General Forum 25 04-08-2015 08:52 AM
Had to get one tire replaced, where to put it? malave7567 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-29-2014 07:33 AM
Can this part be replaced? czar07 Cosmetic Modification (Interior/Exterior/Lighting) 17 11-07-2012 02:46 PM
I may have had the first ever manufacturer-replaced FR-S VZ86 Scion FR-S / Toyota 86 GT86 General Forum 12 05-13-2012 01:39 AM
