Old 11-13-2017, 12:25 PM   #99
Shady195
Drives: '13 10 Series FRS #1203
Originally Posted by mav1178 View Post
Don't forget the sound. If an ITB setup can make the FA20 sound better (i.e. 4AG w/ 20V ITB) then it's a worthwhile mod, especially with the right intake to maximize the sound.
So true because the FA20 sounds like garbage.
Call me silly, but as a drifter, i want people to think my car looks and sounds good. unfortunately, even with boost the FA20 sounds like a turd
I haven't heard a single one thats made me "break my neck" as they say that wasn't some ungodly built thing that revs past 8 grand
Shady195 is offline   Reply With Quote
Old 11-13-2017, 12:35 PM   #100
Shady195
Originally Posted by Tokay444 View Post
This engine does not like to rev that high without more work.
Tell that to Nissan, who put this type of system on the R32-34 Skyline GT-R as a factory design with a rev limit of 7500, same as our engines.
This type of mod isn't for the average end user, it's for specific types of people that have some need that can't be addressed via other aftermarket parts. Judging by the type of responses these two ITB threads have given, it's safe to say 99% of the end users will be happy with a good header paired up with a tune and factory intake box.
Apples to oranges.
You're neglecting the fact that's a boosted motor.
@Tokay444 you're extremely dense
@mav1178 i think in your quest to prove your point, you also missed where this totally went wrong
@Tokay444 worded it things poorly. Your statement basically reads as a big broad general statement that ITB's are useless if you're not revving the engine to the moon
@mav1178 Took the statement at face value with it poor wording and assumes @Tokay444 is an idiot
The both of you continue to bicker arguing over a misunderstanding neither one of you has actually seemed to grasp yet.
@Tokay444 is trying to say that this is useless on a stock NA Car, and not worth the money
@mav1178 is trying to explain its purpose and overall gain regardless of the motor setp
Thats at least what I got out of it, if nothing else it was entertaining
The Following 9 Users Say Thank You to Shady195 For This Useful Post:
arkanist (11-13-2017), CSG Mike (11-13-2017), fika84 (11-13-2017), JazzleSAURUS (11-13-2017), Mim (11-14-2017), Spawn_Of_Creation (11-14-2017), Teseo (11-13-2017), weederr33 (11-13-2017), wparsons (11-15-2017)
Old 11-13-2017, 12:40 PM   #101
gtengr
Drives: 2017 BRZ
... The interesting bit is what ITBs let you do with the rest of the intake system for both NA and FI.
Say you were to make a larger intake plenum for some reason without changing anything else on the car. When you open the (single) throttle, the higher pressure air has to fill that space first before you can fill the cylinders. With ITBs you can tune the intake(s) however you want, and still have fantastic throttle response.
Exactly! It's more complicated than just moving the throttle body. The plenum will allow for resonance tuning.
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
Spuds (11-13-2017)
Old 11-13-2017, 01:01 PM   #102
ajh88
Drives: 2013 Firestorm FR-S
Originally Posted by armstrom View Post
I don't understand the obsession with HP/Torque gains... That's a very crude way to measure the value of a mod.
Amen. Plenty more to this car than power; frankly you bought the wrong car if Hp/torque is all you care about. These ITBs are the kind of mod you do to improve response, sound, have something cool, or max out an NA build.
2013 Firestorm FRS
1995 Alpine Silver Supra Turbo
Toyota Lexus Club of Pittsburgh
ajh88 is offline   Reply With Quote
Old 11-13-2017, 05:13 PM   #103
Tokay444
I don't understand the obsession with HP/Torque gains... That's a very crude way to measure the value of a mod. WOT throttle dyno runs are fine for showing raw power increase but they are incapable of measuring things like throttle response. Sometimes a modification is worth it to the buyer just because it moves the torque curve around a little bit. People spend money on all sorts of mods that cannot show gains on a dyno: lightweight flywheels, lightweight pulleys, carbon fiber driveshafts, different rear-end ratios, you name it.
Why bash the product? If the vendor (SARD or Greddy) were in here making wild claims about the product then there might be something to say. If this mod isn't for you, then move along. People spend twice as much as these things cost just on paint and body work all the time. No one is forcing anyone to buy this product.
-Matt
Except lightweight pulley, flywheels, and drive shafts WILL show gains on a dyno.
Old 11-13-2017, 05:15 PM   #104
Tokay444
@Tokay444 didn't make the the original statement that ITBs wouldn't be good below 8500rpm.
Old 11-13-2017, 05:52 PM   #105
Hawk77FT
Drives: GTS 86
Originally Posted by PuslarBrrrz View Post
Our heads flow pretty well as it turns out. The cams are limiting for NA but still pretty aggressive for stock. There was a shop that ran 13.5 comp pistons with an other wise stock block and made 215-220whp. This is with our standard E85, tune and exhaust mods our course.
"made 215-220whp." I call this BS! tell me the name of the shop please! and their mods, as well as the type of dyno they used!
Hawk77FT is offline   Reply With Quote
Old 11-13-2017, 05:59 PM   #106
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Depends the gear you make the dyno. In 5th or 6th gear will not show anything.
Apart from this, I read different comments from different members. It looks that some people don't really understand why some of us insist to stay NA.
Old 11-13-2017, 06:05 PM   #107
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by nikitopo View Post
Depends the gear you make the dyno. In 5th gear will not show anything.
Also depends on the resistance of the dyno. I imagine some have greater resistance (in whatever form that takes) than others. But we digress...
Old 11-13-2017, 06:08 PM   #108
Spuds
The Dictater
Spuds's Avatar
E85 is wonderful stuff when you are just talking power and tuning. I think 220 whp is not too difficult on e85 even without messing with internals. Granted, each dyno and day is a bit different so your questions are fair.
Old 11-13-2017, 07:48 PM   #109
CSG Mike
CSG Mike's Avatar
I think 215-220 is reasonable for 13.5:1 comp with Ethanol, considering 205whp is already done on a stock engine with just an Ace header and ethanol. OEM front pipe, OEM exhaust, OEM intake!
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Hawk77FT (11-13-2017), JazzleSAURUS (11-15-2017), wparsons (11-15-2017)
Old 11-14-2017, 12:59 AM   #110
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
On el headers, full exhaust system, pullies, intake, throttle body spacer, air duct snorkel and e85 i made 205whp and 165torque so hmm.....
Dr. BRZ is offline   Reply With Quote
Old 11-14-2017, 02:40 AM   #111
Spuds
The Dictater
Spuds's Avatar
Would you happen to be running aftermarket wheels and/or tires? Was it a hot day? Ots tune or custom? Catback, intake stuff, and pulleys aren't going to make much difference compared to just headers anyway.
Unless you are aware of all this and being sarcastic, in which case it didn't work...
Old 11-14-2017, 04:14 AM   #112
PuslarBrrrz
I don't blame the skepticism.lol I ran across the dyno on a 86 Fackbook group, can't find it since it was months ago but it clearly stated 13.5-1 compression as a mod on the dyno print out. I have a few dyno charts saved in the 215-220 whp range but they don't list the mods like the one I saw in particular. PTuning and DBW were the shops.
PuslarBrrrz is offline   Reply With Quote
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 01:20 PM
SARD CF Intake Pipe, SARD Oil Catch Can, TRD Oil Cap, Rad Cap, Battery Clamp Trojan_SC Engine, Exhaust, Bolt-Ons 19 03-28-2018 08:52 PM
Bad news good news ls1ac BRZ First-Gen (2012+) — General Topics 2 10-01-2016 10:11 PM
SARD 86 GT1 Body Kit + SARD LSR Wing nigel-jdmparts Cosmetic Modification (Interior/Exterior/Lighting) 1 04-27-2015 01:41 PM
