Old 11-08-2017, 09:20 PM   #1
Kalebhall
Drives: 2013 Subaru BRZ limited
How much boost can the stock fa20 handle?
I was wondering if anyone knew what the limit is on boosting a brz. I have a t3 6063 turbo pushing 6.6 psi on stock fueling making 278 whp. I’m planning on getting a boost controller and upgrade the injectors and fuel pump and I’m shooting towards 350-400 whp is that too much on the stock engine?
Kalebhall is offline   Reply With Quote
Old 11-08-2017, 09:33 PM   #2
http://www.ft86club.com/forums/showthread.php?t=103574
http://www.ft86club.com/forums/showthread.php?t=38494
http://www.ft86club.com/forums/showthread.php?t=37077
http://www.ft86club.com/forums/showthread.php?t=42222
http://www.ft86club.com/forums/showthread.php?t=78361
http://www.ft86club.com/forums/showthread.php?t=67992
http://www.ft86club.com/forums/showthread.php?t=46778
TachyonBomb (11-09-2017)
Old 11-08-2017, 10:27 PM   #3
Grady
Grady's Avatar
Way to much information.
Simple answer, It will handle as much horse power as you can give it. Until it breaks.
The Following 2 Users Say Thank You to Grady For This Useful Post:
Strife26 (11-30-2017), Tcoat (11-10-2017)
Old 11-08-2017, 11:25 PM   #4
trigun286
trigun286's Avatar
Drives: '16 WRB Limited
Stock power is what, 160-170 wheel on a good day, no way in hell the stock motor can handle 3 times that.
Sent from my Nexus 9 using Tapatalk
trigun286 is offline   Reply With Quote
Old 11-08-2017, 11:34 PM   #5
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
higher octane
HKz is offline   Reply With Quote
Old 11-10-2017, 03:59 AM   #6
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
If you run e85 you should be able to hit 350 whp easy.
tyler_win_photo is offline   Reply With Quote
Old 11-10-2017, 06:26 AM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
You said you only wanted around 250 at first (that's how everyone starts out).... pushed it to 278... now you want 350.... or 400.... then what? Either you blow the engine or want more. There's no stopping.
From all the threads I have read here, 278 is about the safe limit, then you will start to break shit. There's not only the engine and fueling, but driveline, gearbox, tranny etc etc. You're going down a rabbit hole that can only be filled with money.
So the only answer is- the stock engine will take however much money you want to shovel inside of it.
guybo is offline   Reply With Quote
The Following 2 Users Say Thank You to guybo For This Useful Post:
Tcoat (11-10-2017), whataboutbob (11-30-2017)
Old 11-10-2017, 09:17 AM   #8
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I'm a rare kind of guy. I'm making 300whp and I feel like that shit is a little too much.
When I was stock making 160whp the power was 6.5/10 for me.
Now at 295-300whp it's like 12/10...haha
I'm way more than happy.
I'm at 11 psi on Shell 93. But sometimes I hit 12.3 psi in cold weather
SUB-FT86 is offline   Reply With Quote
Old 11-10-2017, 11:26 AM   #9
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Tell us when you find it...
I like driving!
86 South Africa is offline   Reply With Quote
Old 11-10-2017, 11:36 AM   #10
This ^^ is the only answer required!
Anything else is just anecdotal or speculation.
People have blown up at stock and others have run 400+ with no issues (none they will admit at any rate).
The more money you throw at the car the more likely it will survive.
/ thread.
rb6freak (11-13-2017), TachyonBomb (11-10-2017), whataboutbob (11-30-2017)
Old 11-10-2017, 12:23 PM   #11
Kalebhall
I’m in utah and they don’t really have anywhere I can get e85 only 91
Old 11-10-2017, 01:33 PM   #12
mrg666
pessimistic skeptic
mrg666's Avatar
You know that gasoline engine rated for XXX HP does not run at XXX HP always. If you boost the engine to XXX HP and do street driving only, it might very well be okay. If you drive it on track frequently, it fails much sooner. So, the answer is "it depends". Every engine is different and when you are pushing design limits and deviating from the standard equipment, those differences are even more important. If you are boosting the engine, you are rolling your dice. Don't believe anybody if they say their engine is fine. If you had asked what supporting mods are important for the reliability of an engine boosted to a specific level, that would be a better discussion. Then, we could discuss the driving conditions, boost level, and corresponding modifications like oil cooler, catch can, radiator, forged pistons and rods, injectors, fuel pump, etc.
Now, if I say my engine is fine for street driving at 7-8 psi boost with a standard JRSC (factory tune), oil cooler and catch can, will you care? I rolled my dice and I am happy with it
The Following User Says Thank You to mrg666 For This Useful Post:
Tcoat (11-10-2017)
Old 11-10-2017, 02:13 PM   #13
It all boils down to risk and what any individual considers to be an acceptable level of it. Any change increases the level of risk. There are things you can do to mitigate some of that risk but it still increases. If a person understands the level of risk that doing or not doing something will create and can live with it then all is good. If they do not fully understand or push things above the level they are willing to accept then they will have a bad time when something goes wrong.
Contrary to popular belief there is very little that angers me but guys that push things too far, blow up an engine and then then whine and cry about it while trying to blame everything and everybody but themselves just pisses me off to no end. I just want to shout "You had to know you were raising the level of risk so what the hell is your problem now"! Don't even get me started on the ones that do it and then say "I am going back to stock for warranty".
mrg666 (11-10-2017)
Old 11-10-2017, 04:18 PM   #14
mrg666
pessimistic skeptic
mrg666's Avatar
Agreed, that is down right fraud.
I told my dealer if they would accept servicing my car the first time I went there after it was supercharged. They were happy to do that; they were even excited to see the car at dealer. I know they have every right to deny warranty if there is a problem. Once the original design was stretched to this extent, it is first of all my responsibility to keep it running and maintaining. But, I enjoy the car even more this way with a stronger feeling of ownership.
Tcoat (11-10-2017)
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 02:22 AM
What is good boost for the FA20 now? Exhaust Forced Induction 16 12-05-2015 09:52 PM
How much extra hp/trq can the stock tires handle sci3 Scion FR-S / Toyota 86 GT86 General Forum 7 10-31-2015 02:36 PM
How much can stock drive shaft handle?? Argento_FR-S Forced Induction 24 06-01-2013 08:54 PM
FA20 Fuel lean at high boost fix cf6mech Forced Induction 15 05-20-2013 04:33 PM
