#43 | |
Drives: Red 2013 BRZ Premium 6MT
| The Following User Says Thank You to runfrodorun For This Useful Post: | Tcoat (11-08-2017) |
#44 |
I have your sig link opened in another tab, I hope I can get to doing the adjustment some time in the next week, otherwise it will have to be a thing for next year.
#45 | |
I seem to be blessed with a perfect tranny so I am always baffled when somebody has issues. They apparently were not all made the same.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Capt Spaulding (11-09-2017), runfrodorun (11-08-2017) |
#46 |
I agree its strange, but I just don't see how I could be driving this poorly after a million miles in manuals. I do appreciate your diligence though, if I'm doing something wrong I would want to know, since it's my wallet that gets punished for it. I'm going to try doing the clutch adjustment and see what happens with that. the symptoms do reek of a poorly adjusted clutch, and I thought that I ruled that out but in light of some of this new information, I'm going to go back to that. I could see somebody wanting to delay the travel if they tracked it, because then they would want more force in the fully engaged position to prevent slip under high stress situations.
#47 |
#48 | |
Now that we have remove technique for the list I have to go with Ultra on that it seems to be more clutch related than synchro. I can see one tranny being beat on with bad synchros but the new one should not be the same. The coincidence is more than my poor feeble mind can accept.
| The Following User Says Thank You to Tcoat For This Useful Post: | runfrodorun (11-08-2017) |
#49 | |
I just met with a member, and we compared cars. His shifted /significantly/ nicer than mine with the original transmission in it. /S-i-g-n-i-f-i-c-a-n-t-l-y/. If I push the clutch in extra hard and wait a long time, and then shift with a lot of force, it seems to go in without as many complaints, but it still chatters and grinds just a tad once in a while. Will adjust next summer, and hope to god that that solves the problem. I will be a very happy guy if it does. |
#50 |
#51 | |
Obviously, something is messed up in the drivetrain of that car and it may not be worth your time and aggravation to try to figure it out. I recall, back-in-the-day, I bought a new Austin Marina. I thought it would be a handy, practical little vehicle for my wife to drive. I tried soooo hard to like that car ..... ![]() That car was nothing but a pain in the ass. You name it ...... it went wrong. Finally, the differential started grinding, so I opened it up, gad what a mess, so, I closed it back up and filled it up with axil grease. I sold the car to this hot shot young man, that was a f _ _ _ ing know it all. THE END humfrz PS @Tcoat ,have I told this story before ......
#52 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | humfrz (11-08-2017), Ultramaroon (11-08-2017) |
#53 |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (11-08-2017) |
#54 |
I remembered the no-brainer while driving home tonight. Bleed your system to make sure it isn't just air taking up travel!
#55 | |
I did some experiments with the clutch. I think it's totally disengaged anywhere less than 1.5inches from the floor, pretty generous amount of room. I could lift it up an inch, and slide it into first, then take it out without moving my foot, and then slide it back in and it would still be lined up and not spinning, meaning its still totally disengaged. so I think it's probably adjusted just fine. I think I could have gotten away with higher. if I wanted to move forward, it was about 1.5 inches that I had to be at to feel it start to grab. Just didn't see the sense in sitting there trying to grind my transmission in the parking lot, seemed silly. It was still skipping two or three teeth going into 5th almost every time, and once in a while it was still skipping a tooth or two going into 2nd, but it was significantly better. So I guess the take away is this transmission is ridiculously cranky when its cold and still skips a few going in? I'll still try the clutch adjustment, maybe do a bleed in the spring but idk if anything will change. We'll just have to see. |
| The Following 2 Users Say Thank You to runfrodorun For This Useful Post: | humfrz (11-09-2017), Ultramaroon (11-09-2017) |
#56 |
Drives: Black Panda BRZ
Interesting reading. I'm another long time manual driver (European, never owned an automatic) and your transmission sounds very similar to mine. I'm on my second brz and they both are my least favorite gearboxes. Unpredictably stubborn and grindy some days, other days a slick delight to drive. Depends a bit on if I'm tired or not, but that doesn't explain it all - the other household car is an STi and that never grinds unless I really screw up the change. With the first brz I spent hours adjusting the clutch, changed to at least 5 different brands of oil, perrin transmission support, no better. With the 2nd brz I've changed the clutch slave as per ultramaroon's guide and the clutch feel is better for sure, but I've kept the original oil.
One thing I've noticed is the tranny is very sensitive to how I disengage the clutch - if I drop the clutch pedal after lifting off the gas to precisely where the car is coasting, no engine braking at all - then it usually slides easily into gear. If I lift off the gas a bit too much before pushing the clutch, so the car is engine braking, it almost always grinds or hesitates into the next gear. |
| Getting a new transmission from warranty, how long did it took? | Terruko | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 08-14-2017 10:58 AM |
| Transmission Warranty Anyone? | bmacfrs | Engine, Exhaust, Transmission | 2 | 05-15-2017 11:13 PM |
| Which dealer to go for transmission warranty | ironsurfer129 | Southern California | 17 | 02-21-2015 03:16 PM |
| Warranty Work With Mods + Extended Warranty | Wyattkb | Issues | Warranty | Recalls / TSB | 3 | 01-20-2015 04:23 PM |
| Transmission warranty. | Reaper | Engine, Exhaust, Transmission | 28 | 10-10-2014 06:29 PM |
