#1107 |
Drives: 2015 f150 crew cab 4x4 '13 FRSraven
#1109 |
Drives: 2013 Subaru BRZ
With the use of romraider, is there any way to disable LTFT using the OFT like you can on ECUTEK? Goal is to constantly have the ecu tuning itself and not story long term fuel trims to no longer cause short term to spike to compensat.
#1110 |
WRBLUE BRZ
Drives: 2016 Subaru BRZ
Is it possible to convert temperature in OFT to Celsius ?
#1111 |
Drives: 15' Limited BRZ
Hey guys I have a huge problem. I have a open flash header on a stage 2 e85 time I came to understand I can pass New York State inspection because only one of my monitors won’t be ready (o2) but when I went to do inspection all of the monitors are not ready (Evap and fuel) I have about 1,000 miles since my battery died. I just reset my battery and drove about 100 miles and all of my monitors aren’t ready. Any ideas what I can do should I go to the base tune?
#1112 |
Drives: BRZ SWP Limited -6MT
in for solution. texas also has 1 un-ready monitor that can pass. im curious if going back to stock tune would pop a CEL because of the altered exhaust flow from aftermarket components affecting the rear o2 sensor.
#1113 |
IG thomas50shades
Drives: ISO: BRZ
I posted this separately, but I was under the impression that the OFT would have the capacity to explain why my CEL just triggered. Apparently not as it reads "NO ECU ISSUES" or similar.
Am I wrong to assume it reads CEL status, or perhaps the CEL status that was triggered is not related to ECU? I dunno... This thread w/ pic - http://www.ft86club.com/forums/showthread.php?t=122728 |
#1114 |
Took one for the team and I’m flashing back to original file will update if it works
#1115 | |
Drives: '17 BRZ Dark Grey Sport-tech 6MT
This might be repeating information for you but just incase: Some obd2 monitors require multiple warm up and cool down cycles. Clearing codes or detaching the battery resets the tests so you will not want to have the emission test right after reseting even if you drive 100 miles. Here is a good background article: https://www.obdautodoctor.com/scanto...tors-explained |
#1116 |
The CEL has a lean code when flashing back to stock. I’m on e85 uel
I suspect the e85 is fucking up the fuel and evap sensors I may need to finish this tank of e85 put 93 and then flash back to stage 2 93 uel to get those two sensors ready. I’m getting worried I wen through the heat cycle and whatever and it still isn’t working hope flashing back to 93 tune works. |
#1117 |
Drives: Asphalt FR-S
i'm about to give up, hope you guys can help me out because i get no email reply and the call help line has a FULL answering machine, downloaded the manager and now on the step where it wont generate files, i downloaded the zip folder but none of the files fit the size, any ideas? i know that sounds kind of vague but does anyone have a direct download or am i opening them wrong?
#1118 | |
btr.life
Drives: 2022 GR86
Did you already download/backup the stock tune from your car? Do this first. You have the latest Openflash Manager v1.28.0? http://www.openflashtablet.com/downl...1_28_0.exe.zip And you have the v2.076 OTS map set? http://www.openflashtablet.com/downloads/OTS_v2.076.zip It is pretty straightforward in Openflash Manager to load the OTS .bin file for your car, onto the tablet. Go to the Upload tab, and select your tune file on the right. Then select load or upload...cannot remember exactly. I think download tab also shows what tune files are on the tablet. This video might help, although the quality kind of sucks: http://www.openflashtablet.com/downloads/OTS_v2.076.zip I should have made a good video of this when I had my OFT...
| The Following User Says Thank You to justinco For This Useful Post: | Strife26 (11-01-2017) |
#1119 |
Drives: '17 BRZ
Hey guys,
I have a '17 BRZ MT with the old engine (EU Model) and recently installed a Tomei UEL header. I tried to tune the car using the OFT I purchased brand new but failed because it couldn't generate any files for my car. I know this is because the OFT doesn't recognise my ECU calibration and I should download the tunes, v2.076, on my computer and upload them to the OFT. I tried to do that but couldn't find any available tune files for my ECU calibration which is ZA1JK00G. (The only tunes available are for 700G, A00G, A01G, A02G, D00G ECUs) I thought my calibration code is something that the Openflash guys have never seen before so I emailed them and also Shiv, twice, but didn't get a reply. Is there anything I can do at this moment or do I have to keep bothering Shiv and wait for a response? My OFT and Openflash Manager are up to date. I don't want to drive the car too much without a proper tune and already missed a track day because of that so any help is greatly appreciated. Thanks in advance
When you feel like life is passing you by, downshift.
instagram.com/brz.07/ |
#1120 | ||
Drives: Toyota GT86
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
| The Following User Says Thank You to elBarto For This Useful Post: | justinco (11-01-2017) |
| WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 08:13 PM |
| Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 09:27 PM |
| FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 03:08 PM |
| FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 03:49 PM |
| Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 08:14 PM |
