Huge E85 fan!
Drives: 2016 Scion FRS
Perrin and Whiteline bushing combo impressions
This weekend my son and I installed this bushings kit from FT86 Speedfactory http://www.ft86speedfactory.com/perr...combo-435.html and it took about 2 hours on our backs with the car on Jack stands. 1 person could do it but 2 makes it a lot easier.
I didn't remove the FP, but I disconnected the rear part of it from the MP. I also didn't remove the underpanel I just removed 3 bolts and bent it aside. You need a set of sockets and some extensions but not much else. I'm no mechanic but I'm good with this sort of thing; my son doesn't know a socket from crescent wrench. So anyone can do this mod really. I expected a lot of gear whine but there's very little extra. There's a little more general noise and vibration in the car but not a ton. This is the most subtle mod I've done to my car. One caveat is that my exhaust is pretty loud and I already had a lot of vibration so YMMV. Shifting is better and a lot tighter but but not like a short shifter kit tight. There used to be a lot of slop shifting into 5th but this mod took care of that. Also acceleration feels different which I didn't expect and I can't explain. It's subtle. So far after 200 miles I love it but it's not a huge change. I'd do it again considering it's a cheap mod and FT86 speedfactory has excellent service. |
| The Following User Says Thank You to guybo For This Useful Post: | StraightOuttaCanadaEh (10-31-2017) |
#2 |
Drives: 15 BRZ LTD, 05 FXT
I did the Whiteline bushing insert and Kartboy rear shifter bushing together, along with the Whiteline rear subframe insert kit. Overall the package made the rear end and driveline feel much more connected to my inputs, and got rid of the clunk in the trunk.
That combo is my preference, and the additional gear whine is A) nice, and B) is about an equal NVH as the trunk clunking you lose. Glad you liked the combo, consider the rear subframe inserts next! Edit: This feller right here! - http://www.ft86speedfactory.com/whit...l#.WfifcPlSyUk
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | guybo (10-31-2017) |
#3 |
Drives: '13 FRS - STX
+1 on rear subframe bushings
Rear differential inserts were the only mod I've made to the car that made the gf go 'wtf it sounds broken' Stiff coilovers, tire noise, driving around with all the stuff in the trunk removed, nothing phased her, but those diff bushings did. Getting some wheel hop on launches, I'm tempted to put one of these in in the hopes of reducing that... |
#4 | |
#5 |
Huge E85 fan!
I did subframe bushings on my Gencoupe and it was one of the mods that made the most difference. The first time I drove after installing them I couldn't believe the difference it made. Not subtle at all.
I've always thought the FRS felt tight and lacked that slop so I never considered subframe bushings. That said, this thread is changing my mind |
#6 |
You should check out the front shifter bushings, improves on the feel you’re taking about.
| FS: Whiteline Positive Shift & Perrin Rear Shifter Bushing + Whiteline Front Diff Bus | neilvosko | Brakes, Suspension, Chassis | 1 | 11-21-2016 02:44 PM |
| FS: Perrin/Whiteline shifter bushing/support combo 40$ - SOLD | trueno86power | Transmission and Driveline | 4 | 07-09-2015 07:59 PM |
| Whiteline positive shift kit and perrin shifter bushing review | Raven604 | Engine, Exhaust, Transmission | 7 | 04-30-2015 04:10 PM |
| Perrin Shifter Bushing/Tranny Support Combo | 14BRZ | Transmission and Driveline | 1 | 06-20-2014 12:51 PM |
| Whiteline transmission bushing and Perrin shifter bushing review. | Superhatch | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 12-09-2012 08:40 PM |
