Old 10-25-2017, 12:57 PM   #421
adrixe
adrixe's Avatar
Drives: 2014 Subaru BRZ
where can I DL the ver 3 tune for stage 2?
adrixe is offline   Reply With Quote
Old 10-25-2017, 01:11 PM   #422
ChuBRZ
Drives: 2017 BRZ |Yellow series/Limited|
v3.2 Tunes
I have the tunes. Directly emailed from Shiv for the 2017 ECU. If you need them let me know. PM me with your email, and I'll send them to you.
-EDIT-
For the 2014 model go to the OFT website. They have them there.
ChuBRZ is offline   Reply With Quote
Old 10-25-2017, 01:29 PM   #423
bzdont
Drives: 2014 BRZ Limited SWP
Just checked the OFT website Downloads section, there are no Version 3 tunes there.
bzdont is offline   Reply With Quote
Old 10-25-2017, 04:38 PM   #424
BCB75
Drives: 2016 BRZ Limited
Can someone help me determine which tune I should throw on my car (2016 manual)? I just got my OFT Monday. I flashed the v 2.07x stage 1 91 octane tune for the moment.
So, I have 93 available everywhere here. I also just got myself a V1 openflash header (not one of the new V2/3 ones). I would like to know the best tune for now, and the best tune for when I put the header on in a few weeks. I am confused by the following options:
91 vs 93 octane tunes. Should I go 93 if its available here? I see people mentioning no 93 tunes, or just using a 91 anyway?
v2.07x vs v3.0x tunes. Should I attempt to get the v3 tunes from Shiv? I emailed Monday morning and still have not received any answers.
Stage 2 UEL tunes vs OFH specific tunes. Are these specific tunes only for the v2/3 OFH? Are there any downsides to running this one instead of the generic?
Thanks guys, hopefully someone here can help.
BCB75 is offline   Reply With Quote
Old 10-26-2017, 11:13 AM   #425
bzdont
BCB75 -- I think you're a bit confused. There is only one available header from Openflash. On the website, OFH refers to the header only; OFH2 refers to the tablet + the header; OFH3 refers to the tablet + the header + overpipe.
Regardless of whether you get the overpipe or not, here's the deal:
If you're running the stock header (ie., not the openflash header and/or overpipe), then you can use the STAGE 1 off-the-shelf tunes from the website.
If you've installed a non-Openflash header (with or without a new overpipe), you should use the STAGE 2 off-the-shelf tunes.
If you've installed the Openflash header (with or without a new overpipe), you should use the Stage 2OFH tunes (v1.01) shown on the website.
In all cases, whether you use 91 or 93oct is entirely up to you; latter are a bit more aggressive, so make sure you're in fact using 93 gas in that case.
Most of the discussion in this thread is about the new v3 tunes, which are to the best of my knowledge only relevant for 2017 models (which have a different ECU map).
Old 10-26-2017, 02:55 PM   #426
BCB75
bzdont - see this thread for information on OFH v2/3 release
http://www.ft86club.com/forums/showthread.php?t=100751
I picked up an old one that is from before this update was made. It also seems to be around the same time that the OFH specific tunes were created (which I also think may have been created for the v3 with the integrated OP). I figured there might be enough difference that mine would be considered a "generic UEL" at this point.
The package with the tablet can be ordered with the OFH2 or OFH3.
So just to confirm, a 93 tune will be more aggressive, and the v3 tunes are only for 2017+ cars?
EDIT: Actually found a post from Shiv in that thread stating "Same tune regardless of OFH1, OFH2 or OFH3 " so I should be good with that one.
The Following User Says Thank You to BCB75 For This Useful Post:
OrangeGuitar (10-26-2017)
Old 10-27-2017, 03:27 PM   #427
BCB75
Bzdont - shiv also just sent me a message with v3 tunes for my 2016. Just thought you might want to know they are out.
Old 10-28-2017, 07:36 AM   #428
kvt95
Drives: Toyota 86
Hi there
Looking for the v3 ZA1J___I ROMS(EU 6AT). Specifically the stage 2 uel tune. Does anyone know if these are out yet? I've emailed Shiv 3 times but he has not replied to me at all.
Any help will be much appreciated
kvt95 is offline   Reply With Quote
Old 10-28-2017, 09:01 AM   #429
steve99
Drives: FT86
Originally Posted by kvt95 View Post
Hi there
South africa you only have 95 ron fuel, the v3 tunes are for good usa 93 aki rated fuels this is usually better than 98 ron.
With 95 ron you rearly need a customised tune
Pm me i can help you out
lutfy (10-31-2017)
Old 10-28-2017, 11:42 PM   #430
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Originally Posted by PuslarBrrrz View Post
Torque dip is still present with the '17 model.
Much less than it was, not even as issue on the stock car.
PetrolioBenzina is offline   Reply With Quote
Old 10-31-2017, 12:51 PM   #431
Jasonb
Drives: 17 Series Yellow BRZ
I’ve never driven the earlier year models but it was immediately obvious with my 17 even during the quick test drive. I still bought the car knowing a uel header and tune would fix it. I got a jdl uel and oft after driving the car stock for a couple months and they definitely fixed the torque dip. So it’s still present on a stock 2017.
Jasonb is offline   Reply With Quote
Old 10-31-2017, 01:14 PM   #432
invaliduser
Drives: 2017 86
Most dynos I've seen of the 2017 with header and tune still show a torque dip. I know mine still has it but it's prob 50% better than it was stock
Sent from my Pixel 2 XL using Tapatalk
invaliduser is offline   Reply With Quote
Old 10-31-2017, 01:51 PM   #433
Somerandom18
Drives: 2017 manual BRZ
The dip on the 2017s has been narrowed but is slightly deeper.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 11-01-2017, 12:02 AM   #434
Jasonb
I don’t feel it anymore, that’s for sure. The power builds as the rpms increase now just like it should. Acceleration from 2,500 rpm and up it just builds power and I do not feel an obvious dip where it used to be. Before there was a decent amount of low end torque, and then an obvious dip, then it felt like a mild “vtec” kicking in sort of feeling after the dip was over. Now it’s just smooth.
OpenFlash Tablet: Multiple Data Log files! Shiv@Openflash Software Tuning 95 11-09-2017 09:40 AM
OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download Shiv@Openflash Software Tuning 1062 08-13-2017 05:13 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet v1.55b: BIN files added! Shiv@Openflash Software Tuning 525 04-09-2014 10:42 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
