| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: FRS-ULTRA(lol)marine
slavcyl piston lube/goo?
Hey all,
I started getting a squeaky noise out of the top of the transmission a couple weeks ago. kidnapped a friend, and had them press on the clutch while the hood was popped to see where the noise was coming from. Best I can tell, it seems like it was coming from the slave cylinder, and it also appears to be missing some what I assume to be lube. I am a phenomenally lazy Googler, but I did a quick search and couldn't find much other than "sometimes it happens." Anyone have any idea what kind of lube this should be, and if I apply new lube, if I should clean off the original stuff (if yes, with what?) Thanks! |
#2 |
http://bfy.tw/EemQ
actually, here, use this one. I can only endorse my own comments on the subject. http://bfy.tw/Eemk
#3 | |
I'll try to get a sound clip of it over the next few days. |
#4 |
Nope. It isn't. BTW, if you just compress the plunger in the slave by pulling forward on the fork, you can get a couple seconds of looseness where you can jiggle the fork in the main pivot.
That'll get you on the right track.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | mmcelroy (10-24-2017) |
#5 |
The Dictater
Drives: '13 Red Scion FRS
First result in that search ultra linked is for the slave cylinder. At least it works on my machine.
#6 | |
"Quick & dirty: 1. Detach the slave cylinder. Leave the hydraulics alone. 2. Remove the dust boot from the fork. 3. Reach down behind the fork with a finger and feel for the pivot. It's going to be tight because of the retaining clip. 4. Squeeze a decent glob of Lucas Red & Tacky #2 in there with your finger. 5. Jiggle the fork to distribute the grease as much as possible. It'll work in more on its own. 6. Put a dab of grease in the top pivot where the slave pin goes. 7. Reassemble." ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | mmcelroy (10-24-2017) |
#7 |
@Ultramaroon
I definitely did not click the first one since you suggested that you could only speak for your own experience. My first response came out a lot more snarky than I meant to, I do greatly appreciate it. @Spuds I did not check the first one... serves me right! @humfrz Sounds simple enough, thank you! |
| The Following 2 Users Say Thank You to mmcelroy For This Useful Post: | humfrz (10-24-2017), Ultramaroon (10-25-2017) |
#8 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (10-25-2017) |
#9 | |
I'll give you that it sounds like it comes from up high. Others will swear it comes from inside the cabin. Yeah, agreed. He can stay.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (10-25-2017) |
#10 |
The Dictater
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | mmcelroy (10-25-2017), Ultramaroon (10-25-2017) |
#11 |
#12 | |
potato vid |
| Cricket Killer, Injector lube ? | BC-Boy | Engine, Exhaust, Transmission | 58 | 10-02-2018 03:33 PM |
| Plano Tx - Quaker Steak & Lube Meet | 20firestorm13 | Southwest | 1 | 06-03-2013 05:55 PM |
| So my girlfriend took the car to Jiffy Lube... | Mandy | Other Vehicles & General Automotive Discussions | 24 | 04-08-2013 03:35 PM |
| How shall I lube? | jimmillion | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 11-17-2012 02:13 AM |
| Anyone change transmission lube yet? | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 08-21-2012 06:47 AM |
