#4201 |
Round 3 Racing
Drives: Scion FR-S race car
Yes, I searched. If it is here, I didn't find it.
I need a dyno comparison between the standard JRSC pulley on gas (98 or 100 preferred, but 93 okay) and the high boost JRSC pulley. Same fuel requirements. No E85. If you don't want to post, please consider sending to me via PM or I can give you my email address. This is for confidential discussions with SCCA to consider allowing the high boost pulley in my class. The dyno info will not be released. It will be used by the rules committee at SCCA which is bound by a confidentiality agreement. It doesn't even need to be an overlay comparison. What I really need is the dyno chart for the high boost pulley (C38 preferred) on gas. |
#4202 |
Round 3 Racing
I found this and it seems to match what I have been told verbally.
http://blog.vittuned.com/tag/frs/
#4203 | |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
This is my car and is your best bet |
#4204 | |
#4205 |
Drives: 2017 86
anyone have any experience with the C38 with RS pully, in term of power gains?
#4206 |
Drives: Subaru BRZ
Tried searching thread but not yielding results
Those of you on a carb tune on 91 CA gas- how much whp are you pushing?
'16 SWP BRZ
#4207 |
#4208 |
Drives: Subaru BRZ
Thanks Mike
Paired up with a FlexFuel kit, E85 and a proper flash/tune, would there be a significant change in reliability? I've heard E85 runs cooler, but an increase in power should negate that? Looking to go this route in near future, will def shoot you a PM when ready
'16 SWP BRZ
#4209 | |
You will need a clutch, MAP sensor, injectors and fuel pump to go with the E85. |
#4210 |
#4211 | |
Drives: 2013 FRS / 2013 427 Vert
If this is a straight up comparison of the 110 pulley vs the 100 then I would really like to source a compatible 90mm pulley and lower the redline.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#4212 | |
#4213 | |
Unfortunately I have a C30 at the moment. Is that a 90mm pulley by chance?
[SIGPIC][/SIGPIC]
#4214 |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
