Old 07-05-2012, 10:53 PM   #1
TRD_86
Drives: 2013 86 white
0 to 60
http://www.zeroto60times.com/
I usually check out cars from this site. They do have fair real true test data collection, not like those conservative car factory specs.
Frs at 5.9s
Brz at 6.1s
The insideline tested the Brz show at 7.3s ! what the heck with this insideline driver or recorder ? I did couple times w/ my frs and I feel it damn fast for this car and it should be in the low 6s compare to my current IS350 in the low 5s. The 86 is not that slow like the insideline editor driver. Has anyone checked it out yet w/ real proved source data? Please discuss and tip in !
http://www.insideline.com/subaru/brz...and-video.html
TRD_86 is offline   Reply With Quote
Old 07-05-2012, 11:12 PM   #2
Luis_GT
I'm surprised by how many reviews place the FR-S/BRZ as a 7 sec 0-60 car... I know it lacks a bit of torque... but my 530 is capable of going from 0-60 in just a bit less than 7 seconds and it only has 25 more HP and 70 more tq... as well as 700 more pounds... The BRZ should, on paper, be faster than my car.
The Following User Says Thank You to Luis_GT For This Useful Post:
TRD_86 (07-05-2012)
Old 07-05-2012, 11:13 PM   #3
FRSowner
Drives: Hot Lava A/T
Pick up a G-tech and do your own tests. The older models can be bought for just a few bucks on eBay and they flat out work.
FRSowner is offline   Reply With Quote
Old 07-05-2012, 11:17 PM   #4
TRD_86
I know. Just screw insideline !
Old 07-05-2012, 11:22 PM   #5
wallace03
wallace03's Avatar
Drives: WRB BRZ
ive always noticed zeroto60times.com have different times than the factory estimated on every car. also my current car has 200hp and is about 3600lbs, and i feel like it has plenty of go-go
wallace03 is offline   Reply With Quote
Old 07-05-2012, 11:25 PM   #6
alyon
What what I have heard to get times around 6 seconds you need to do a clutch dump which is above the torque dip... So you're dropping it around 5k.
Many of the mags don't feel like putting it through that much abuse. Other mags such as motortrend are not afraid of it and routinely do big clutch dumps to get the lower times.
They did the same thing with the WRX to get that 5.2 second time (or whatever low 5 sec time).
alyon is offline   Reply With Quote
The Following User Says Thank You to alyon For This Useful Post:
TRD_86 (07-05-2012)
Old 07-05-2012, 11:32 PM   #7
TRD_86
Yes, this is what the pro racer would do on the track. Know the car and race for the money !
Old 07-06-2012, 12:19 AM   #8
Tbxgz
Tbxgz's Avatar
Drives: 2013 BRZ Limited 6MT
I usually check out cars from this site. They do have fair real true test data collection, not like those conservative manufacture specs.
Frs at 5.9s
Brz at 6.1s
The insideline tested the Brz show at 7.3s ! what the heck with this insideline driver or recorder ? I did couple times w/ my frs and I feel it damn fast for this car and it should be in the low 6s compare w/ my current IS350, but it not that slow like the insideline. Has anyone test it out yet w/ real proved source data? Please discuss and tip in !
I think edmunds was launching the car at 3500 rpms while MT was getting mid 6 launches with a 5k clutch drop. Lesson? Avoid the 3-4k torque drought.
Edit* I think I saw one of subaruwrxfan's video where he took his car to ~60 in about 7 seconds with a slight roll out and no clutch drop.
Tbxgz is offline   Reply With Quote
Old 07-06-2012, 03:58 AM   #9
SFTiofoso
Drives: '10 Civic Si Coupe
Maybe the large discrepancy has to with some shifting to 3rd gear to get to 60 while others simply letting 2nd bounce of the rev limiter.
SFTiofoso is offline   Reply With Quote
Old 07-06-2012, 04:04 AM   #10
TRD_86
I found this clip. He launched w/ clutch drop at 6.2s which is what I feel fast enough for this car. It's a 6 seconds car period.
[ame="http://www.youtube.com/watch?v=tPoZ1SC8uwk"]2013 Scion FR-S: A New Hope? - Ignition Episode 14 - YouTube[/ame]
Old 07-06-2012, 07:49 AM   #11
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
The numbers are good considering the OEM tires
adprokid is offline   Reply With Quote
Old 07-06-2012, 09:15 AM   #12
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
That torque helps a lot on a 0 to 60. My car feels slow to me until I am above 25 mph and then start rowing gears.
One thing to keep in mind when reading straight line stats for this car is to pay attention to what it does from 50 to 100. It's much more competitive. I lost a casual stoplight race with a mini copper s up to 50 or 60 in my car vs a friend. 0 to 30 I was a car length back and still almost reeled him in before I quit a bit below 60 mph. This was without launching the car.
blu_ is offline   Reply With Quote
Old 07-06-2012, 09:18 AM   #13
#87
I usually post drunk
#87's Avatar
Well there is no "bouncing" it cuts at the limit so I don't think you can do that, can you?
#87 is offline   Reply With Quote
Old 07-06-2012, 09:20 AM   #14
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
I think getting mid 6s out of a 2l na car isn't bad myself. 0 to 60 is always going to this cars worst stat.
Remember the car will still do 140mph
