Old 10-03-2017, 07:45 PM   #15
empower-auto
Kouki-Monster
empower-auto's Avatar
I concur and decided it was a characteristic of the car I would have to live with.
If you're bothered by the lag between pedal and engine response then yeah, flywheel won't help, if you're bothered by how long it takes for the engine to spin up that's a flywheel change. Downside of the lighter flywheel loses revs more quickly as well potentially making upshifts awkward.
I think it just commands more throttle input. If you spin the engine properly to match your drive-line / desired response, a lighter flywheel is very rewarding.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 10-03-2017, 08:08 PM   #16
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I find stock rewarding as-is
ineedyourdiddly
Old 10-12-2017, 01:12 PM   #17
empower-auto
Kouki-Monster
I guess it depends what you're doing with the car. There's no blanket answer. My goal is circuit performance and for that a light flywheel is fantastic especially with the quick inputs
Rich Anderson
EMPOWER AUTO
Old 10-12-2017, 01:15 PM   #18
strat61caster
That's fair, I do mostly autox and aside from the launch and 2-4 shifts per run there's much more time and satisfaction to be gained elsewhere.
Plus rulesets keep a lot of things stock :P
ineedyourdiddly
Old 10-13-2017, 09:53 AM   #19
Gloonge
Drives: 2013 frs raven
I tried all the suggested fixes short of actually doing the clutch swap. None of them actually fixed the engagement point like I hoped, but they did make the pedal feel a little bit better.
I have decided to go ahead and do the clutch and light flywheel swap, I will likely do the MTEC shift springs while im in there.
My question is, is there a tail shaft/output plug for this trans? I just recently <10k miles ago just changed the fluid to Motul, and I would like to not have to spend another $60 on fluid. Or can someone chime in with the diameter of that seal?
Gloonge is offline   Reply With Quote
Old 10-13-2017, 10:12 AM   #20
Drain it into a clean bucket. Strain it and pour it back in.
Old 10-13-2017, 10:28 AM   #21
Gloonge
I like you, No idea why that didn't come to my mind.
I even have one of the motul bottles left, I can use that to put it back in the trans.
Old 10-13-2017, 10:40 AM   #22
Throw a bit of cheesecloth between the containers when you transfer it and it will filter out any contaminates that may be there. Don't forget to wipe down the magnetic drain plug as soon as you pull it.
Old 10-13-2017, 10:48 AM   #23
Gloonge
Agreed, cheese cloth is a better idea than the metal strainer in my funnel. I hope not much has collected on that magnet in just 10k miles, I cleaned it when I pulled the original.
Old 10-13-2017, 11:33 AM   #24
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Be sure to change your throwout bearing when you replace the clutch. Mine totally exploded a little over 60k miles. I think Toyota has released an updated TOB that's supposed to fix the issue.
smg1138 is offline   Reply With Quote
Old 10-13-2017, 12:03 PM   #25
Gloonge
The clutch kit comes with one, so that should be covered.
I don't know if the kit comes with a new pilot though, I am not sure how the original pilots are holding up.
Old 10-13-2017, 12:55 PM   #26
Mine has started singing the song of it's people. Apparently it's people are Banshees.
In all the failure threads I don't recall ever once seeing an issue with the pilot.
Old 10-13-2017, 08:54 PM   #27
Suzy is their queen.
...i think i just found my car's name.
Old 11-03-2017, 12:44 AM   #28
akahenry
akahenry's Avatar
Drives: '18 STi
@Gloonge How are you liking your new clutch setup? How's the daily drive-ability, especially with the lighter flywheel?
akahenry is offline   Reply With Quote
Help!! Car Wont Start After Clutch Swap (25$ reward for solution!!) bren5279 Issues | Warranty | Recalls / TSB 44 07-03-2017 08:36 AM
My Goals with this Forum!!! ORGANIZED-CHAOS Scion FR-S / Toyota 86 GT86 General Forum 153 08-01-2016 01:35 PM
Can I get help with my goals? Sulee417 Scion FR-S / Toyota 86 GT86 General Forum 16 05-03-2014 09:12 PM
What are people's car goals? darkonion Northern California 31 04-17-2014 08:06 AM
Swap out OEM clutch, OEM synchros/gearbox brzadmir Engine, Exhaust, Transmission 19 05-04-2013 03:13 PM
