Senior Citizen
Drives: 2015 WRB BRZ
ST Suspensions Coilover kit, 3k miles.
SOLD!!!!
#2 |
Senior Citizen
This was how the car sat with them.
| The Following 3 Users Say Thank You to Dan37BRZ For This Useful Post: |
#3 |
Drives: 2016 Scion FR-S
Very curious about what type of wheels those are, also do you have some type of cover on your wheel well that lessens the wheel gap? Your car is beautiful!
| The Following User Says Thank You to ACEintheCROWD For This Useful Post: | Dan37BRZ (09-23-2017) |
#4 | |
Senior Citizen
I do have TRD fender extensions and yes they do lessen the wheel gap by about a 1/2". Check out my build thread here for more details. |
#5 | |
How come you are getting rid of your ST coilovers? I didnt see a replacement set in your build thread. With your setup, the stance is spot on IMO. |
| The Following User Says Thank You to ACEintheCROWD For This Useful Post: | Teseo (09-24-2017) |
#6 |
Drives: 2013 FRS
these fit on 2013 FRS?
#7 |
Senior Citizen
#8 | |
Drives: 15 BRZ LTD, 05 FXT
#9 |
Senior Citizen
Price drop to $600 picked up!!!
#10 |
Drives: 2013 FRS
do these come with top hats?
#11 |
Senior Citizen
#12 |
Drives: M4
whats the reason for selling? Getting something else instead?
#13 |
Senior Citizen
My car always had a problem with the rear passenger always sitting higher than the rest of the car, like substantially higher. Doesn't matter what suspension I went with, same with my Bilstein B14 Coilovers, and with these. Since the difference was so much, it would affect the spring rate/spring preload with how much adjustment I needed to do to the rear right in order for it to be even.
I figured in order for me to compensate for the ride height difference, I needed coilovers where I can adjust the preload and then adjust the whole shock body for height so I don't mess with the spring preload. I bought some HKS HiperMax just for that. Turns out when installing my HKS coilovers I remembered I never correctly set the upper bushings on the rear upper control arm, once I did it corrected my ride height difference in the rear. ![]() ![]() If I would have figured out this in the first place, I wouldn't have switched. I would have stayed with the ST and saved my money. |
#14 |
Senior Citizen
Price drop, $575 picked up!
| ST Suspensions Coilover Kit - Made By KW | tlinspired830 | Brakes, Suspension, Chassis | 28 | 03-04-2014 02:15 PM |
