Old 09-26-2017, 09:34 PM   #1
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Question Set up FFS and LC and a few other things.... now no cruise control
Does LC or FFS disable cruise control?
I also edited the timing advance B map for pops and bang and raised the low idle RPM to 800. Could these disable cruise?
there's no CEL, car runs perfectly otherwise. Just no cruise after tweaking my Stage 2 EL 93 OFS tune file
TY for any help
guybo is offline   Reply With Quote
Old 09-26-2017, 10:32 PM   #2
steve99
Drives: FT86
TY for any help
Read ecu for fault codes, if codes found investigate cause and rectify
If no codes
remove battery terminal for a couple of minutes to reset all control units
hopefully cruise will be back
guybo (09-27-2017)
Old 09-27-2017, 07:04 AM   #3
guybo
Huge E85 fan!
guybo's Avatar
So there could be fault codes disabling cruise even if there's no MIL (CEL)? OK, I never thought to do that. I thought only active MIL could disable cruise, not pending or anything.
Old 09-27-2017, 07:13 AM   #4
steve99
Drives: FT86
Oft and some other scanners only read codes from engine ecu, and overlook all the other control units in car
Old 09-27-2017, 11:59 AM   #5
D_Thissen
D_Thissen's Avatar
TY for any help
Disconnect the battery for a minute or two. I've had a similar issue when I plugged in my OFT while the car was running. I guess the plug didn't go in straight, got the white screen, and then the CC didn't work. I turned off the car, plugged in the OFT again and everything worked fine.
Old 09-27-2017, 10:06 PM   #6
guybo
Huge E85 fan!
guybo's Avatar
That did it, thanks guys
Cruise control malfunction totally Issues | Warranty | Recalls / TSB 20 02-26-2018 10:13 PM
Nexus 7 Volume Control with Cruise Control RavioliG Electronics | Audio | NAV | Infotainment 8 12-06-2016 02:38 PM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 08:37 AM
Cruise Control nospoons Scion FR-S / Toyota 86 GT86 General Forum 34 06-17-2014 03:28 PM
Cruise control notout86 Scion FR-S / Toyota 86 GT86 General Forum 50 05-13-2013 03:01 AM
